Nestle Posted October 30, 2006 Posted October 30, 2006 I am printing the control surface picture to use that for the drilling marks, but because I don't have any required applications, from that small image at ucapps... I would like to know what are the exact proportions to keep the front panel 1:1 with the holes of the circuit boards... 40 cm width seems to be pretty close.Thanks,Roope
Mr modnaR Posted October 30, 2006 Posted October 30, 2006 if you mean the Schaeffer panel, use Front Panel Designer, and hit Ctrl+O which brings up the object properties window. then, click on each hole in turn and it will give you measurements from the bottom left corner of the panel.
Nestle Posted October 30, 2006 Author Posted October 30, 2006 Ok, thanks... I think I got it. Tomorrow I will turn into mr. Driller...R
