Hex and Decimal Notation in C Source
jackchaos
What is the difference of writing this:
MIOS_MIDI_TxBufferPut(0x06)
and this:
MIOS_MIDI_TxBufferPut(6)
I notice this in looking at other peoples source that hex and decimal notation is used interchangably.
P.S.
I have 80% of my hardware completed and mounted in 2 cardboard boxes so I have something to write software to before I decide on the front panel design.
It's very exciting to see my project come together and even more so when I can almost tweak every audible characteristic of the matrix sounds with my knobby programmer.
I've ordered some more parts from SmashTV and those will allow me to complete the 5 point tracking/reshaper, ramps and portamento section of the front panel.
I've also ordered a larger LCD (2x20) which I havn't added yet which is part of the final electronic component, the programmer section.
there are no difference between
MIOS_MIDI_TxBufferPut(0x06) and MIOS_MIDI_TxBufferPut(6)
but there' is a big one with MIOS_MIDI_TxBufferPut(0x10) and MIOS_MIDI_TxBufferPut(10)
0xValue Mean hexadecimal value.
The value 'alone' mean it's a decimal value.
0x10 has the decimal value of 16 ( 0x10 = (2*8 + 1*0) )  ;)
<edit> see below! Seppoman explains it right, and I'm the one who gets an F in his Math Exam... like always  :-[ </edit>
hex gets counted from 0 to 7 15 (as the name implies),
decimal from 0 to 9 (dito)...
as the computer treats all numbers in the last instance as binaries (0 or 1), it's upon you what makes more sense to use...
eg. channel calculations are a lot easier to implement in hex than in dec.
See http://www.midibox.org/dokuwiki/doku.php?id=midi_specification
Regards,
Michael
Hi Michael,
hex gets counted from 0 to 7 (as the name implies),
I´m sorry, but this is not correct. Hex gets counted from 0 to 15 - as the name implies, because the full name is "hexadecimal" which means 16. From 0 to 7 would be the octal system which is not used in programming (or nearly anywhere else ;) ).
About hex to decimal conversion: Just as decimal e.g. 25 means 2*10 + 5*1, hex 0x10 means 1*16 + 0*1. The digits from right to left in all systems mean (number * (base to the power of the digit )) - the digit is counted from 0. So with hex it is
digit:   ...       3                  2              1               0
power :  ...       16^3               16^2           16^1            16^0
equals:  ...       4096               255            16              1
so e.g. a 4 digit hex value of 0x3A20 means (3*4096 + 10*255 (A hex=10 dec)  + 2*16 + 0*1) = 14870 :)
The reason why hex is often used in programming is that it converts quite nicely to binary. Each binary "Nibble", that is 4 bit, is represented by one hex digit, that´s because 4 digits binary also represent numbers from 0 to 15. So you can calculate the binary value of large hex numbers in your head and don´t have to use a calculator all the time.
Greetings from Nerd-Land :)
Seppoman
