Sasha Posted November 24, 2006 Report Posted November 24, 2006 Can I use PIC16F88 adapter for programming PIC16F84(A) i need for some other project? They are pin cpmpatibile.What about programming software and voltages? P18 at 12.5V, right?
Sasha Posted November 28, 2006 Author Report Posted November 28, 2006 PIC16F84 is pretty popular. Somebody here muste be using it before?Please, give me some info.
Wilba Posted November 29, 2006 Report Posted November 29, 2006 I've used PIC16F84 before, long time ago, I burned them with a JDM programmer without any problems.If the programming pins are the same (I think they are, but compare the datasheets yourself) just try it with the same voltage as recommended for PIC16F88, it should work. If the programming voltage (VPP) is higher than expected, I think it will still work, and won't kill it ;)
Sasha Posted November 30, 2006 Author Report Posted November 30, 2006 Yes, as I said they are pin compatibile. I was concerned about voltages and maybe some options I sould check or uncheck. I`ll give it a try as it is 16F88. Thanks Wilba
Jaicen Posted November 30, 2006 Report Posted November 30, 2006 AFAIK, and i'm far from an expert on these things! The difference is just that the A can handle more current. Just check the datasheets on microchip.com.
Sasha Posted November 30, 2006 Author Report Posted November 30, 2006 The difference is just that the A can handle more current. Just check the datasheets on microchip.com. I think you get we are talking about differences betveen A and normal version?It is abot 16F88 and 16F84 programing compatibility
Sasha Posted December 20, 2006 Author Report Posted December 20, 2006 PIC 16F84A can be burned with PIC burner and P18 software. ;)
