DJSail Posted November 26, 2006 Report Posted November 26, 2006 I've been searching for pots and I've come up with these Alps ones they seem perfect but I'm not quite sure what is meant by snap in! Are they panel-mountable? Do you mount the case then simply push the pots into these case?!Any replies woudl be greatcheers
Jidis Posted November 26, 2006 Report Posted November 26, 2006 Hi,I think that link is unique to your computer. I got a "session expired" error, but browsing that site, I saw some of the Alps "snap-ins". I'm guessing they're just talking about those two outer pins (attached to the casing). They're the type that have that curved lump in them, so that they push through a hole and sort of lock themselves in place (like the tip contact inside a tip-ring-sleeve phone jack). Basically standard solder type pots with a couple anchors. I have a bunch here. Just make sure you get linear taper and non-detented (unless you want that).Someone please correct that if it's wrong. 8)George
