multi function button handling
Screaming_Rabbit
Hello
Does anybody know about it's possible to implement following multi function button handling by programming?
Description:
I'd like to have 4 or more "shift" buttons (Shift 1-4) to select the functions for Buttons A+B.
Example:
- I press and hold [shift1] the functions the MidiBox sends now would be "CUT" for [buttonA] and "PASTE" for [buttonB]
- I press and hold [shift2] the functions the MidiBox sends now would be "JUMP to Clip Left" for [buttonA] and "JUMP to Clip Right" for [buttonB]
- I press and hold [shift3] the functions the MidiBox sends now would be "JUMP to Marker Left" for [buttonA] and "JUMP to Marker Right" for [buttonB]
... and so on
Logical Shematic:
    Button B ___/  _____________________________________________
    Button A ___/  _______|____________|____________|________    |
                        Shift1/--/            2/--/              3/--/            4/--/
                          |    F  F              F  F              F  F            F  F    |
                          |    u  u              u  u              u  u            u  u    |
                          |    n  n              n  n              n  n            n  n    |
                          |    k  k              k  k              k  k            k  k    |
                          |    t  t              t  t              t  t            t  t    |
                          |    i  i                i  i                i  i              i  i    |
                          |    o  o              o  o              o  o            o  o    |
                          |    n  n              n  n              n  n            n  n    |
                          |    1  1              2  2              3  3            4  4    |
                          |    A  B              A  B              A  B            A  B    |
Thanks and Greets
Roger
screaming
Are you doing this in assembly or C?
I do something like this in my project. It looks something like this.
From DIN_NotifyToggle() I have ButtonHandler(pin)
/* global var */
shiftmode = 0;
/* you simply toggle a shift mode to an ON state.
 * If you want to hold down a shift, then simply check the pin to see if its currently closed.
void ButtonHandler(unsigned char pin) {
	switch(pin)
		case DIN_A_Button:
		switch(shiftmode) {
			case MODE1:
				DoCut();
				break;
			case MODE2:
				DoJumpLeft();
				break;
			case MODE3:
				DoJumpMarkerLeft();
				break;
			<etc...>
			break;
		case DIN_B_Button:
		switch(shiftmode ) {
			case MODE1:
				DoPaste();
				break;
			case MODE2:
				DoJumpRight();
				break;
			case MODE3:
				DoJumpMarkerRight();
				break;
			<etc...>
			break;
		case DIN_Shift1:
			shiftmode = MODE1;
		break;
		case DIN_Shift2:
			shiftmode = MODE2;
		break;
		case DIN_Shift3:
			shiftmode = MODE3;
		break;
		case DIN_Shift4:
			shiftmode = MODE4;
		break;
