Guest walrus Posted December 10, 2006 Posted December 10, 2006 This is my design for my SONAR midiboxChannel ControlsLevel (Fader)MuteSoloRecord Pan or send 1Trim or send 2ok so if I have calculated this correctly there are...56 AIN (36 Pots, 20 Faders)48 DOUT (LEDS)67 DIN (52 Channel buttons, 5 Transport, 2 Bank, 8 Function)1 4x20 LCD displaythis equals2 AIN Modules2 DIN Modules (3 if can use the midibox 128)2 DOUT ModulesThats all correct isnt it?I know i got 67 DIN which is why im posting to ask do i really need the function buttons?Is the only difference between the 64 and 128 the firmware or do u need another core?What do u think of my deisgn and are there any changes that you think i should make?
Geerinckx Posted December 12, 2006 Posted December 12, 2006 Hi,No i don't think you need them! You can modify the function buttons in de asm file i think, i'm not sure because I'm waiting for the PCB's from SmashTV for my own MB64 & MB128 I only need 30 AIN's for pots & faders but 192 DIN's for buttons and touch sensor's I'm using the QT160 or the QT110 for the touch sensors. Does anny1 have some experiense whith this IC??GrtzzGert
