MIDIBOX16 Learning  more than one instruction
Hello
i make a midibox 64 with 16 pot and have a big problem
i have an EA-1 (Electribe EA-1 for novice) :P but when i turn the cutoff pot my EA1 send 3 instructions , and one of this have value 0-127 for a simple cut , it's normal but my midibox learn the first and i can't reproduce the cutoff.
is it possible for each pot to save more than one instruction
ex 2 fix instructions NRPN  ??? and a variable ??
Thanks, Olivier
Hi Olivier,
NRPNs can be sent by using meta events. However, MIDI Learn function will not help here.
I will send you the source code so that you are able to program the meta information
