e-toy Posted January 13, 2007 Posted January 13, 2007 As I am planing to make a Filter extension for my MidiBox SID, I have a few question about the use of AOUT_LC in the MIDibox SID project.I like to have a small (2 channel) AOUT module like the AOUT_LC, but I'm not really happy with the fact that Filter resonance will only have 4 bit (16 steps), so my question regards mostly this problem.Since I read that the Filter cutoff parameter of the SID SW can be interpolated, I think Filter resonance will still have max 128 steps (no interpolation). Right ?How much steps (or in other words, bits) have the smoothed cutoff signal ?Currently 12/4 Bit is the only supported output format of the AOUT_LC (for MB_SID). But it seems that theoretical all combinations of max 16 bit could be possible (eg. 9/7 bit). Right ? Is it just a matter of HW configuration and the driver ?Wich CV format will the AOUT_LC (controlled by the SID SW) provide ? V/Oct or Hz/V ? e-toy
TK. Posted January 14, 2007 Posted January 14, 2007 Hi,yes, the resonance cannot be interpolated. Internally it works with 7bit resolution (128 steps) as you assumed. The SID itself has only a 4bit register for resonance.CutOff has internally 16bit resolution (65536 steps), the SID provides a 11bit register for CutOff.Currently 12/4 Bit is the only supported output format of the AOUT_LC (for MB_SID). But it seems that theoretical all combinations of max 16 bit could be possible (eg. 9/7 bit). Right ?Is it just a matter of HW configuration and the driver ?yes, you could even combine 3 shift registers instead of 2 to output 16/8 bit resolution, the changes have to be made in sid_aout_lc.incWich CV format will the AOUT_LC (controlled by the SID SW) provide ? V/Oct or Hz/V ? the output curve is linear, don't know if we can speak about V/Oct when no oscillator frequency is controlled by the CVBest Regards, Thorsten.
