Rigo Posted January 14, 2007 Posted January 14, 2007 I had the same problem and put all resistor networks correctly but now I have a problem with a button that keeps triggering constantly 3479587 1 -- 151 84 127 8 C 6 Note On 3479659 1 -- 151 84 0 8 C 6 Note Off 3479726 1 -- 151 84 127 8 C 6 Note On 3479760 1 -- 151 84 0 8 C 6 Note Off 3479863 1 -- 151 84 127 8 C 6 Note On 3479897 1 -- 151 84 0 8 C 6 Note Off 3479967 1 -- 151 84 127 8 C 6 Note On 3480001 1 -- 151 84 0 8 C 6 Note Off 3480036 1 -- 151 84 127 8 C 6 Note On 3480070 1 -- 151 84 0 8 C 6 Note Off 3480109 1 -- 151 84 127 8 C 6 Note On 3480142 1 -- 151 84 0 8 C 6 Note Off 3480176 1 -- 151 84 127 8 C 6 Note On 3480211 1 -- 151 84 0 8 C 6 Note Off I had a realy hard time desoldering the resitor networks, so am thinking that i might have damaged one or two, I actualy disconnected the button but it just keep going, is this behavior due to something else?
smashtv Posted January 14, 2007 Posted January 14, 2007 Hi Rigo!I made a new thread with your post, so it won't get buried or dilute the other thread.....This looks more like the serial clock line is shorted to an input than a bad resistor network, but it depends on the timing of the messages.If it follows a solid timing pattern, Look for a clock or data line shorted to that input....If the timing appears more random, it -could- be the resistor on that input line is not connected (and the input is floating).Let us know what you find..... BestSmash
Rigo Posted January 15, 2007 Author Posted January 15, 2007 thanks Tim.Well as far as the timing it is constant on-off-on-off but If I turn the unit off for a few minutes (20min) and turnit back on it doesn't start to do that (on-off-on-off) after a minute or twobut am checking for those shorts in the circuit, I'l keep you guys informed
Rigo Posted January 16, 2007 Author Posted January 16, 2007 After a good inspection with a magnifying glass all tracks and soldering seem ok, I found something strange on Inputs (D7 and D6) of J6 with the multimeter every input reads 5V but D7 reads erratically from 2.4V to 4.4V and D6 reads constantly 2.8V. D7 is the one that is constantly triggering the note on/off, what should I do?
smashtv Posted January 16, 2007 Posted January 16, 2007 After a good inspection with a magnifying glass all tracks and soldering seem ok, I found something strange on Inputs (D7 and D6) of J6 with the multimeter every input reads 5V but D7 reads erratically from 2.4V to 4.4V and D6 reads constantly 2.8V. D7 is the one that is constantly triggering the note on/off, what should I do?My first instinct would be to pull that 74HC165 chip and measure again to see if the readings are then stable.....If it's still wrong without the chip then it's either the resistor pack or a soldering issue.Considering these meter results and your close inspection, my bet is on the '165 chip.Let us know what you find! BestSmash
Rigo Posted January 18, 2007 Author Posted January 18, 2007 Hi there, thank you for all your help Well this is what I found;I turn the unit without the 74HC165 chip and check the voltages they seem ok (5.3V) but after two minutes the voltage drops giving me the results I described earlier, am desoldering the resistor network and putting individual ones, in a few days I'll repost with the results
smashtv Posted January 18, 2007 Posted January 18, 2007 Hi Rigo!That's a bit of a suprise, this is an odd failure mode for a resistor pack.....My money was on the chip as the cause. (he said while scribbling notes for future reference) ;)Let me know if the discrete resistors do the trick....Best RegardsSmash
Rigo Posted January 21, 2007 Author Posted January 21, 2007 Hi there again,well I change the resistor pack for individual resistors, and the problem is still there, but I found something else, if I connect D0 of J6 to ground the notes on/off stop triggering constantly, although the only inputs that work are D4,D3, and D2, because the remaining either dont work at all like D1 or trigger 3 notes on/off at the same time like D5,D6,D7, could it be the 74HC165 then.?
smashtv Posted January 21, 2007 Posted January 21, 2007 Hi RigoThis still sounds like a resistor pack issue......Did you change both packs associated w/this chip? (it needs 9 total resitors per '165)Do you have all 4 '165s and their resistors loaded? (just making sure you are not building a DINX1)What happens if you swap the '165s around? Do the symptoms change at all?Let me know what you find....BestSmashTV
Rigo Posted January 22, 2007 Author Posted January 22, 2007 am doing one of your Dinx4, and yes I changed all nine, I changed the registers and same thing.would it be wrong if, for now, I only use the 3 available inputs and leave D0 permanently grounded, would it cause some problems? am still going to check and recheck but I just want to know I have that option. Thank you so mucho for you help.
