mrmeana Posted January 31, 2007 Report Posted January 31, 2007 Hello This is probably a really stupid question but is it possible to implement a midi channel selector (either a rotary encoder or just a push button that incrementally increases) into a midibox 64 project. All I want to be able to do is shift all the front panel controls to a different midi channel via the selector. I know absolutely nothing about MIOS but have read this site and forum repeatedly and can’t seem to find an answer. Cheers Carl Quote
moxi Posted January 31, 2007 Report Posted January 31, 2007 hi,just use the bank:assign all control of bank 1 to channel 1, bank 2 to channel 2, etc...you can add up to 16 butons to access bank directly, or you can change bank with the jog..let see the mb64 tutorial... Quote
mrmeana Posted January 31, 2007 Author Report Posted January 31, 2007 cheers I figured it would be blatently obvious ::) Quote
TK. Posted February 5, 2007 Report Posted February 5, 2007 Note that there is also a "global channel", which overrides all MIDI Channel definitions for the pots and buttons. It can be enabled in the appr. menu pageBest Regards, Thorsten. Quote
snorkman Posted February 10, 2007 Report Posted February 10, 2007 TK,So you mean if I have 4 channels with eq and I use another buttons connected to the core i can assign those 4 channel to another 4 channels on the bank?, I mean like changing the channels but using the same hard? ??? Quote
