TK. Posted February 3, 2007 Posted February 3, 2007 MIOS V1.9d is now available for download; this version got updates for PICs with code space > 64k, a requirement for PIC18F4682 and PIC18F4685From the ChangeLog: o support for PIC18F4685 and PIC18F4682 o initialisation of 4bit CLCD overworked o 4bit CLCD selected by default for PIC18F4685 and PIC18F4682 to free the ECAN pins at RB2 and RB3 Note that the D0-D3 pins of the CLCD should not be connected to the PIC in this case, but clamped to ground instead! o new Bootloader version V1.2b: support for the new PICs Output drivers of Port B are not enabled during the startup phase anymore.[/code]An update is not required for PIC18F452 users, because the behaviour should be almost identical.Only exception: if your Character LCD is connected with the 4bit interface only, it could make sense to try the new release (it would be interesting for me, if your CLCD can still be initialised)[b]Info for programmers:[/b] under migration/ you will find the new include files for PIC18F4685 and PIC18F4682mios.h now contains generic parameters for memory sizes, special registers and workarounds - they are mainly used within MIOS itself, but could also be useful for normal applications.macros.h contains variations for table preload macros when the source code is compiled for PICs with code space > 64k. For such derivatives, TBLPTRU is changed as well.Please note, that the PIC18F4685 and PIC18F4682 are not 100% binary compatible to PIC18F452. RAM from 0x60-0x7f is not directly accessible. BANKED accesses have to be used instead. Some bigger applications which allocate this area could crash.Since this PIC is currently only relevant for future MIDIbox SID versions, an adapted release of MBSID V1.7303 will be available soon, which will in addition support communication via the integrated ECAN peripheral (see http://www.ucapps.de/midibox_network.html)Best Regards, Thorsten.
TK. Posted February 20, 2007 Author Posted February 20, 2007 There is a new MIOS Studio Version available, which supports uploads to code memory range >64khttp://www.midibox.org/mios_studio/MIOSStudio_beta7_5.jar.zipBest Regards, Thorsten.
