lylehaze Posted February 11, 2007 Posted February 11, 2007 Well, I hope "Design Concepts" will work, I couldn'tfind "Stupid Questions", so I'll try here.I have hand-wired a DINX1 to connect a single encoder and a single pushbutton. No problems there, but I need to figure out whether I'll be connecting to J9 or J6 of the core. The application was written by Pilo, to control a PGA4311 chip.I have his source here, but I don't know where to look in the code to see which connector is used for the encoder.I suppose I can try both, but if anyone knows a more definite way to tell, I'd love to know it.Thanks,Lyle Hazelwood
stryd_one Posted February 12, 2007 Posted February 12, 2007 Search for Wilba's recent post on SID CS mods and follow the same logic.
lylehaze Posted February 12, 2007 Author Posted February 12, 2007 Thank You Sir.Got a great deal done yesterday, including first sound check. So far, the quality of the mix is very good. Noaudible noise, even at very high levels :-)Had I not cut myself trimming a header strip, I might be finished already.Off to search for the post you mentioned..LyleHaze
