helitron Posted February 25, 2007 Report Posted February 25, 2007 after a loong period lurking around in this forum and learning how to build my midibox sid, i finally finished the basic part of my sid8580.a big dankeschön to TK and all the others involved in that amazing project i never thought of beeing capable to build on my own ;)herer a small picit still has some loose cables, but that is going to be finished soon, when i get the casing + frontplatethats the fp design (probably i should get some smaller knobs, at least for the menue):btw. although it was not recommendend inthe forum, i used a switching power supply that obviously has a good grounding. the SN ratio is great! there is absolutely no humm or noise or whatsoever. just my 2c on that (from a DIY noob)hel Quote
Wild_Weasel Posted February 26, 2007 Report Posted February 26, 2007 Hi!Nice box and lcd!Could you please post a bigger pic of the panel layout... it's a bit hard to read.RegardsMichael Quote
SLP Posted February 26, 2007 Report Posted February 26, 2007 nice! :)I hope mine will work, too ;)...at least I've got the same enclosure ^^matthias Quote
