In the implementation chart it says that the lowest frequency of the LFOs is 0.001 Hz...
That is once each 1000 seconds!  :o Or abt once every 17 minutes!
Is that correct? or should it be (more reasonable) 0.01 Hz? (which is abt once every 1.5 minutes)? (since the next step is 0.032 Hz or abt once every 1.66 minutes...) ???
this is a calculation error in the script which has generated the table - with the lowest setting, one period takes 65536 update cycles -> 65536*0.00081 = 53 seconds -> 0.018 Hz
