Guest Macwreck Posted September 22, 2002 Posted September 22, 2002 Faders work cool on the MB64 ;D ... but being a guitarist :-/ I want to use pedals in their place ... and here's the problem! I understand you can take an expression or volume pedal and change the pot so that it matches the requirements of the MB64 BUT they cost so much down here in New Zealand!!!! :o Does anyone know of anywhere in the world that makes cheap expression or volume pedals or where the factories are that actually build them! :-[ You guys do such a good job getting all sorts of components for everything else I hoped you could give me some pointers here ...
LO Posted September 22, 2002 Posted September 22, 2002 you could try ALLELECTRONICS (www.allelectronics.com)cat#FSW-11 $16.50usd eachthey are good quality I think, ugly tho!!however I think the postage would kill you?as I am also in NZ and I just got 8 motorfaders from them, which was bad enuf
Guest Macwreck Posted September 23, 2002 Posted September 23, 2002 Thanks for the idea but the 'pedal' I'm referring to is an expression or volume pedal not a sustain pedal - the action is a rocking motion over a central axis not a up/down push motion - they look like this http://www.proelgroup.com/en/products/article.jsp?sctcod=MF108&artcod=PVP12Anyone else know where I can get cheap volume/expression pedals? Pete
