i guys i haqver also this problem
i was working with this pic that sudenly becamed sloooowww as hell
the core module is ok
so i tryed to upload mios again but i get always this message
00000000372599 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372599 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372599 ms | [F8] Timing clock
00000000372628 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372628 ms | [F8] Timing clock
00000000372631 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372633 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372634 ms | [F8] Timing clock
00000000372635 ms | [F8] Timing clock
00000000372635 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372640 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372645 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372648 ms | [F8] Timing clock
00000000372649 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372654 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372657 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372660 ms | [F8] Timing clock
00000000372662 ms | [F8] Timing clock
00000000372662 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372666 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372670 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372672 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372673 ms | [F8] Timing clock
00000000372674 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372679 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372683 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372685 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372686 ms | [F8] Timing clock
00000000372688 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372692 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372695 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372696 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372698 ms | [F8] Timing clock
00000000372699 ms | [F8] Timing clock
00000000372701 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372705 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372707 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372709 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372712 ms | [F8] Timing clock
00000000372713 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372717 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372722 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372725 ms | [F8] Timing clock
00000000372725 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372731 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372734 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372735 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372737 ms | [F8] Timing clock
00000000372738 ms | [F8] Timing clock
00000000372738 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372743 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372747 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372749 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372750 ms | [F8] Timing clock
00000000372752 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372756 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120
00000000372759 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372762 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0
00000000372763 ms | [F8] Timing clock
did i fried my pic?
Slow as hell doing what?
How do you know the core is OK? (It might have broken since it was last OK)
Do you get that msg before trying to upload the new MIOS the first time, or every time you power it on, or after uploading MIOS, or...?
the corew is ok because i tryed it with other pics and it works...
i get that message when i  try to upload every kind of application
Ahh OK, thx for the info... in that case it does seem that the PIC has died :(
Did you try uploading MIOS (The OS v1.9x, not the MBSID application v1.7303) within 2 seconds of powering on the core? That has worked for a few people recently.
If that doesn't work, you could try re-burning the bootloader onto the PIC if you have a burner or JDM.
If I were you, I would double-check for errors on the board, high current from lots of LED's, warning signs like anything hot, etc,.. It would be a shame if there was a problem with the core that takes some time to appear, and you fried another PIC.
Hope that helps!
thanx i'll try to re-upload mios and i'll let u know
in the while i fixed that thing with mplab, but i don't know how...
i deleted so many files that at the end is hard to say wich one was the cause of the conflict
peace
my box is getting slow when the midimerger is enabled and certain midi software forwards midi in to out. Midi ox does, but miosstudio doesnt for example
i tryed to re-upload mios but nothing...
and now the problem is double
because i was needing a slave core
so i tryed to change the id to another pic
but during the upload i got a strange message
and now i have the display that flash alternating
"mios 1.9......"
and some numbers like "700...."
i don't know what happened...
today it's not my lucky day....
