Slorrin Posted March 23, 2007 Posted March 23, 2007 The DIN page, and Avishowtech's info, says if you are using an encoder, to use J6 on the DIn board, but the schematics on the Step A page say to use J9, for both options, encoder OR button.which one is correct?
stryd_one Posted March 23, 2007 Posted March 23, 2007 I searched for ages because I was trying to figure out where you read that you should connect encoders to J9 on the DIN.... Especially as there isn't one... So I assume you're talking about which CORE module jumper to connect the DIN module to? If so, you musta missed this part:MIDIbox16E only ;)So it's still J9. If all else fails, the schematic is the best reference, and you can always check the source code to be sure.
Slorrin Posted March 23, 2007 Author Posted March 23, 2007 argh! There is literally soo much information i cant' contain it all in one brain.. Oddly, i connected it to J9 on the core, but it didn't work.. i got voltage in the right pins.. but.. my buttons.. my encoder.. nadaI even wired it correctly using the revised key (these are R3 DIN boards, so the legend on the board is wrong).. but still, nothing... i can't figure out why i could not enter the menu.. my menu button was wired correctly, and was a working button :(
