As part of the organ I am buildng, I have aquired a bank of 16 illuminated rocker tab switches which come mounted on a single PCB.  Tracing the PCB to the connecting socket it seems that they are arranged as a scan matrix of 4 * 4.  Is there an approach to using a scan matrix of this type with the DIN modules?
Thanks,
James
JimHenry - Thanks for your continued advise, I guessed that this would be the best solution.  Excuse the naive question but, if I was to break the traces on the PCB using a knife, how would I go about adding a new terminal to that trace that I can interface to?  Is there a well documented approach to doing this?
Thanks,
James
I have never seen documentation of how to rework a PCB, sometimes called "cut and jumper." The basic idea is to make two cuts across the PCB trace, perhaps an 1/8" apart and remove the trace between. Sometimes a soldering iron will release the cut trace. Leave enough trace that you can lay a wire flat against the trace and solder it to the trace. If done well the solder should "hug" the shape of the wire rather than being a big blob. Mechanically support the wire somehow, perhaps a dab of hot glue. Find an old PCB and practice before attacking useful boards.
