I have trouble uploading MIOS V 1.9 on my PIC18f452 board. :'(
The log of the upload is included below. The problem occurs when the following block (write?) occurs:
Sending block 00007C00-00007CFF
Received error code 05: Write access failed (invalid address range) - used by 1st level bsl
This was an expected error - please ignore!
The problem persists while trying several different settings in MIOS studio.
Anybody got a clue what's going on?
regards: Hans
Starting upload of mios_v1_9d_pic18f452.hex
Hex file contains code in MIOS range, forcing reboot!
Received Upload Request
Sending block 00000400-000004FF
Received Checksum: 71 - OK
Sending block 00000500-000005FF
Received Checksum: 29 - OK
Sending block 00000600-000006FF
Received Checksum: 40 - OK
Sending block 00000700-000007FF
Received Checksum: 52 - OK
Sending block 00000800-000008FF
Received Checksum: 59 - OK
Sending block 00000900-000009FF
Received Checksum: 37 - OK
Sending block 00000A00-00000AFF
Received Checksum: 6B - OK
Sending block 00000B00-00000BFF
Received Checksum: 7E - OK
Sending block 00000C00-00000CFF
Sending block 00000D00-00000DFF
Received Checksum: 5A - OK
Sending block 00000E00-00000EFF
Received Checksum: 3E - OK
Sending block 00000F00-00000FFF
Received Checksum: 35 - OK
Sending block 00001000-000010FF
Sending block 00001100-000011FF
Received Checksum: 62 - OK
Sending block 00001200-000012FF
Received Checksum: 3A - OK
Sending block 00001300-000013FF
Sending block 00001400-000014FF
Received Checksum: 0D - OK
Sending block 00001500-000015FF
Received Checksum: 0B - OK
Sending block 00001600-000016FF
Received Checksum: 2B - OK
Sending block 00001700-000017FF
Received Checksum: 48 - OK
Sending block 00001800-000018FF
Received Checksum: 6D - OK
Sending block 00001900-000019FF
Received Checksum: 76 - OK
Sending block 00001A00-00001AFF
Received Checksum: 34 - OK
Sending block 00001B00-00001BFF
Received Checksum: 25 - OK
Sending block 00001C00-00001CFF
Received Checksum: 04 - OK
Sending block 00001D00-00001DFF
Received Checksum: 46 - OK
Sending block 00001E00-00001EFF
Received Checksum: 33 - OK
Sending block 00001F00-00001FFF
Received Checksum: 74 - OK
Sending block 00002000-000020FF
Received Checksum: 1A - OK
Sending block 00002100-000021FF
Sending block 00002200-000022FF
Received Checksum: 2D - OK
Sending block 00002300-000023FF
Received Checksum: 1B - OK
Sending block 00002400-000024FF
Received Checksum: 0A - OK
Sending block 00002500-000025FF
Sending block 00002600-000026FF
Received Checksum: 5C - OK
Sending block 00002700-000027FF
Received Checksum: 05 - OK
Sending block 00002800-000028FF
Received Checksum: 1C - OK
Sending block 00002900-000029FF
Received Checksum: 00 - OK
Sending block 00002A00-00002AFF
Received Checksum: 3B - OK
Sending block 00002B00-00002BFF
Received Checksum: 61 - OK
Sending block 00002C00-00002CFF
Received Checksum: 7D - OK
Sending block 00002D00-00002DFF
Received Checksum: 02 - OK
Sending block 00002E00-00002EFF
Received Checksum: 22 - OK
Sending block 00002F00-00002FFF
Sending block 00003000-000030FF
Sending block 00003100-000031FF
Received Checksum: 60 - OK
Sending block 00003200-000032FF
Sending block 00003300-000033FF
Received Checksum: 3F - OK
Error: Received unexpected Upload Request
Aborting after 16 errors
Hi Hans,
it seems that your PIC is running with the old bootloader, which was located at 0x7c00-0x7fff
Just upload the pic18f452/midi/update_with_old_mios.hex file of the mios_update_v1_9d package
This will install the new bootloader and a new MIOS version.
Hi Thorsten,
I tried your suggestion but without success...
Some more info:
The board already worked previously. I demolished the PIC when I was trying to solder an additional power circuit for sd-card support.
I ordered 2 PIC18F452's at Wouter van Ooijen's web shop who also programmed the bootloader for me. I indicated the MIDIBOX website for download so I assume he burned the latest bootloader. I'll check with him...
When I started I noticed the repetitive download requests. So, the bootloader was there and no MIOS installed.
Then, I used MIOS Studio to upload MIOS with the results as displayed in the LOG file in my previous message in this thread.
When I use smart mode the process stops when hitting the 0x07c00 address range.
When I use manual mode the process continues but repeatedly complains about write errors in the 0x7c00 to 0x7fff range.
The LCD keeps displaying the single black top-line. It used to work before, however due to fault connection at a point I may have destroyed it. So this is currently not a reliable monitor for signs of MIOS life.
After MIOS upload a reboot of the board now gives only two sysex upload requests which may indicate that at least part of the MIOS upload was succesfull.
When I tried to upload:
the upload succeeded but the device did not automatically reboot. WHen I rebooted manually : no response on the LCD. To verify whether MIOS was alive I tried to upload an aplication but that failed with no response from the board.
After reading some messages about power requirements during burning I repeated the process using a power adapter allowing 800mA. Without success.
Are there any other options to check whether or what parts of MIOS are alive?
I hope for any other pointers to solve this problem.
regards: Hans
Ha! :) got it working!
I now used
    update_without_installed_mios.hex
and that worked OK! Could upload application. All seems well.
Thanks for the hints, Throsten. I'll keep you updated about sd-card progress...
regards: Hans
