gillesdeshays Posted May 2, 2003 Report Posted May 2, 2003 My SID_16F is sounding great !!!  8)Thanks again Thorsten !I just want to know how can i change patches i've  load with the jsynth (example_patches_v4)by Program change ???in the SID page :V1.4 Patches can now be saved into a BankStick Program Change command switches between the 128 patches of a BankStick I've tryed to send " C0h XXh " with x=preset number ...P: change on the LCD but still on Alien Groove preset ...I try many many things ... without result !Help !Gilles
TK. Posted May 4, 2003 Report Posted May 4, 2003 Hi Gilles,the program change event is the right one to change to another patch. Are you sure that the BankStick has been connected properly? (You will hear a short tune when it is regognized by the MBSID). If the BankStick is not available, every patch number will point to the internal EEPROM (-> to a single patch)Best Regards, Thorsten.
gillesdeshays Posted May 4, 2003 Author Report Posted May 4, 2003 Ok understand now ...There is only one patch in the internal bank ....But the jsynth "load" 128 patch in my SID without any bankstick ....If i understand well ... Jsynth load but the core keep only one patch ...?Thanks !Gilles
gillesdeshays Posted May 4, 2003 Author Report Posted May 4, 2003 I just plug the bankstick ....made some new patches ...Upload with jsynth ......AND SOUNDS TERRIBLE !!!!!!!!!!MBHP SID is taking my nights !!!!! ;DGilles
js Posted May 4, 2003 Report Posted May 4, 2003 @ gillesYou might want to read here:http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1051041533 It sound like the same problem. (and the solution is there too :D )Good luck!!(can´t wait to get my Sid going....)js
gillesdeshays Posted May 4, 2003 Author Report Posted May 4, 2003 thanks for all ...It was my fault ...I read "bank" instead of "patch" in the Sid webpage...In fact, only one patch can be loaded in the PIC if you don't have any bankstick ...I thought it was one bank .... :-[Everything works perfectly now with my bankstick ! ;D Gilles
