Ruff-G Posted April 17, 2007 Posted April 17, 2007 Hi,Does Midibox SEQ V3 support triplet so it uses 6 steps per 4/4 beat?couldnt find any clear answers about that with search function.thx for help
TK. Posted April 21, 2007 Posted April 21, 2007 No, this isn't possible yet, but could be easily added by enhancing the clock divider function.I will add this to the wishlistBest Regards, Thorsten.
TK. Posted May 13, 2007 Posted May 13, 2007 I've added the code for triplets - the implementation of the feature itself was quite easy, but it was difficult to overwork the menu layout so that the new mode can be selected in an intuitive way - however, I think that I found a good solution (now different timebases are available at the right side, like 8, 8T, 16, 16T, ...)The feature + user manual update will be available with the next release (it's already available on request, but I haven't tested if the rest is still working...) Best Regards, Thorsten.
Ruff-G Posted May 15, 2007 Author Posted May 15, 2007 thank you for the fast implementation of triplet to the sequencer.i will test it in the next time. because i am a little bit busy.regardsruff-g
