Alright, I've got two keyboard controllers. I would like to use them both without having to build (or,... gasp!.... buy) an interface with multiple inputs/outputs.
Here's what I'm thinking. -  build a MIDI Y cable. Have the two ends of the Y go to each of the controllers, and the other end of the Y go into my synth rack.
Would that work, and not violate MIDI protocol? Or should I just go get a nice, rackmount, USB interface?
I assume that your controllers do not have MIDI Inputs? Normally you would put them in a chain like so:
Controller 1 Out ------ In Controller 2 Out --- Rack
Anyway the Y adapter would have to be a midi merger.
Hope that helps!
You cant simply connect wires as a "Y" to merge midi signals is this is what you want to know.
You need electronics to merge datas in a logical way.
