Hello,
After a big break doing other stuffs, i finaly found time to finish my mini midi box SID.
Much less nice than i expected, bad varnish, box not totally closed, flashing screen etc...
Anyway it works and i am happy.
I can control every parameter rather quickly  ;D
Xavier
Thanks a lot !
I agree that many things could have been better/nicer.  ;)
I just wanted to add that this is my first DIY project and i could mod it a little thanks to the excellent Documentation !!!
Xavier
Hello Ixox,
Respect – Since its your first DIY-work. Don't be dissapointed. It looks good and if it sounds good, what more can you expect. I'll bet, the next DIY-project wil be absolutely perfect!
Good work,
I want build a small sid synth, mind if i copy your layout? Could i convince you to share your firmware?
Thanks...
My goal was to have everything public in the spirit of all those midiboxes.
So i documented as much as i could here :
http://www.midibox.org/forum/index.php?topic=7569.0
A compiled firmware would be useless because my Dout and Din wiring is very bad and weird....
But i see no problem in sharing it.
If you have any question, don't hesitate.  :D
Xavier
Hey Xavier, nice job! You did it finally... I almost forget about you. :)
I would also like to make one of these after I finish what I already started... my "To Build" list is constantly growing.
