Hi All,
Just ordered my kits from Smash and am looking forward to building the thing (and re-ordering the bits I forgot about being a bit of a plank) but while I wait for the delivery I thought I'd start looking at the application side of things and one of the things I can't find any mention of anywhere in the code examples is reading midi time code in terms of bars and beats.
It must be able to be done for the LC timecode display but what I'm after is to create a "visual click" using up to 6 LEDs on the DOUT module.  Ie stepping through each LED on each beat and starting back at LED one on each bar.  6 LEDs should enable most time sigs, or compounds of..
Any clues on where to start or links to where I can read up on this particular requirement?
Laters, Stef
Stef,
I guess you mean MIDI Clock/Song Pointer. The MIDIMon has routines for that, which should help figure out what stuff you're looking for (in ASM at least).
Good Luck,
George
PS- From what I remember, it doesn't actually disable one of the two (MTC or clock). If you throw it both, it just tries to display both. In Nuendo here, it's no trouble as you can uncheck the one you aren't using in the timecode output panel. May not matter either if you're just grabbing beat/quarter note messages for something else. ;)
My pleasure. That site has been around since like forever too. I owe the name many hours of my time ;)
OT: IMO the best thing about that site is it's name - The MIDI Technical Fanatic's Brainwashing Centre.  ;D
Edit: I just realised my link above skips the frames. You should start at http://www.borg.com/~jglatt/
MIDI is the language of gods.
Lesser life forms communicate in more primitive, less artistic manners such as barks, chirps, roars, or any of the many human verbal languages in use throughout the globe. But, gods communicate using MIDI messages. Even a picture, whose value is often equated to a thousand words, cannot match the scope of emotional and intellectual power unleashed by a stream of MIDI messages. But, try to tell that to the visual-and-print-fixated, tone-deaf heathen who infest this planet...
The MIDI Technical Fanatic's Brainwashing Center is a cyberplace dedicated to those individuals who wish to attain a higher level of existence than that of the plodding, MIDI-illiterate scum around them. Here, you will find MIDI technical documents and programming information, MIDI tutorials which explain various MIDI topics in easy-to-understand terms, MIDI software tools, examples of some very good uses of MIDI (in the form of well-constructed MIDI sequencer files), and blueprints for the surgical installation of a MIDI jack upon the human body so that a musician can directly communicate with his MIDI gear.
WARNING! This Web Site contains pictures of bare male and female DIN connectors, as well as explicit talk about "dumps with handshakes". Before continuing, you must be an adult, preferably one who isn't a hypocritical U.S. legislator who sponsors a "porn" bill while he's cheating on his spouse with an illegal alien prostitute whom he pays (using taxpayer's money) to spank his swollen buttocks with a rolled-up copy of The New Republic.
There are also a lot of annoying, abrasive attempts at humor. Get used to it, or kill yourself.
LMFAO
