URBatORB Posted May 31, 2007 Report Posted May 31, 2007 Hello,what's the difference between rectifier B40C800 and B40C1000. Or better for understanding; what does the indentification say?B = ?40 = 40 voltsC = ?1000 or 800 ?Can I use a B40C1000 instead a B40C800 for the improved SID PSU?Thanks,Daniel Quote
NorthernLightX Posted May 31, 2007 Report Posted May 31, 2007 800 and 1000 are the mA the bridge can handle. The 1000 will work, just watch the pinout, some bridges have a different pinout than you'd expect.I think the C stands for Current and the B for Bridge but that's just a wild guess. Quote
URBatORB Posted May 31, 2007 Author Report Posted May 31, 2007 Thanks for the fast reply. I ordered a B40C800 and got a B40C1000. Now I think the B40C800 were simply out of stock.I have a square DIP Version. I looks like that one:~ IIII -~ IIII +Do you know were I have to connect the 9V AC and the conduction from the Powerswitch? I can't find information according to that rectifier version.Daniel Quote
NorthernLightX Posted May 31, 2007 Report Posted May 31, 2007 Thanks for the fast reply. I ordered a B40C800 and got a B40C1000. Now I think the B40C800 were simply out of stock.I have a square DIP Version. I looks like that one:~ IIII -~ IIII +Do you know were I have to connect the 9V AC and the conduction from the Powerswitch? I can't find information according to that rectifier version.DanielI would place the powerswitch between your mains and the trafo (no polarity because it's AC, so so don't worry about the wires). The AC out of the trafo go to the 2 ~ leads, and then + comes out of the + lead, and - out of the -...quite simple as you can see :) Quote
URBatORB Posted May 31, 2007 Author Report Posted May 31, 2007 OK, I wasn't 100% sure. ;DThanks Quote
