abcmann Posted July 13, 2007 Report Posted July 13, 2007 Firstly hi to everybody, its my first post. I am looking at this page for a long time now and successfully built a little sid already. ;D ;D ;DThorsten ..... GREAT WORK !!I have built a usb_pic module and have 2 18f4550 lying around here :D I read about the eusart bug. :(( Perhaps this helps a little bit even if i dont think?? :http://www.picbasic.org/forum/showthread.php?t=7172I'm not good at programming but this guy writes it works. Or is there already a working firmware for it ? I need to get the clock from the midiout of my dj-mixer to my laptop (which just has usb). Its to syncronise to the running vinyl. I dont wanted to buy a interface.byebye
TK. Posted July 13, 2007 Report Posted July 13, 2007 Hi abcmann,cool that your MBSID is already working on your first forum post! :-)I've cancled the PIC based USB project, but if the guy writes that his firmware is working, I would propose to try it out. Since I'm using the 2x4 MIDI router, I've no personal need anymore for a USB solution (I prefer direct MIDI routing without the need for a PC in order to reduce latencies)Best Regards, Thorsten.
jld Posted September 22, 2007 Report Posted September 22, 2007 Hello,Just bumped into this forum (BTW, a lot of interesting things!) while looking for a simple MIDI out USB DIY board.(I am looking for simple and low cost solution to midify an organ pedalboard that could be plugge directly to a PC USB port)I understand there are still issues with the UART on the 18f4550 but I guess it should work perfectly for MIDI out through the USB port (would it also work with the UART when doing MIDIout only?)Would it be OK to re-use the USB part of the code you have developped for the 18f4550? Thanks,JLD
TK. Posted September 23, 2007 Report Posted September 23, 2007 Hi,a snapshot of this project can be found here: http://www.ucapps.de/tmp/mbhp_usb_pic_snapshot.zipFor your "simple" interface, NUMBER_MIDI_INTERFACES should be set from 5 to 1 in usbdsc.c (by default, it is assumed that 4 MBHP_IIC_MIDI module are connected in addition, resulting into 5 MIDI In and 5 MIDI Out ports). IIC_MIDI_MAX_NUMBER should be set from 4 to 0 in iic_midi.asm, otherwise you need to add some additional pull-up resistors to the core (I guess the RA0..RA3 pin + RD5) in order to avoid random effects.Best Regards, Thorsten.
