cimo Posted August 31, 2007 Report Posted August 31, 2007 hii am quite sure i ve seen this posted already but can t really find it..I need to drive 3 leds from a single DOUT pin, the rest of pins will drive 1 single led.If i want all the leds to have the same brightness, is it enough to change the resistor value or should i go for a transistor?simone Quote
Screaming_Rabbit Posted September 1, 2007 Report Posted September 1, 2007 Hi Cimohttp://www.midibox.org/forum/index.php?topic=3513.0Greets, Roger Quote
