sineSurfer Posted September 4, 2007 Report Posted September 4, 2007 Hi everyone, after some time I decided to go for the MIDIbox Sid, but as a good newbie I need some help here.I'd like to start with 1 Sid chip plus all the controls and MIDI IN/OUT, something like this one: http://www.midibox.org/midibox_gallery/tino3.jpgIf anyone can help me to figure out what kits and extra stuff I need to get from SmashTV to get going.btw. i'll be reusing the case and power supply for a commodore coming my way.Thanks in advance for all the help you can give me! ;D
Sasha Posted September 4, 2007 Report Posted September 4, 2007 Hellow sine surfer. Welcome aboard. I want give you complete list of parts, but you should check the MBSID step C. Good luck
sineSurfer Posted September 4, 2007 Author Report Posted September 4, 2007 Thanks Sasha, this list would do?Modules:1 core1 sid1 ltc(the core gives MIDI activity on LEDs or just this module?)3 DINX42 DOUTX41 2x20 LCD1 bankstickExtras:PSU38 switches99 LEDs1 detented encoder14 rotary encodersDINs, jacks, etc.Another question, it's possible to use faders instead of encoders for all the envelope controls(SH9 style)? what modules would I need to change/add to make it work this way?Thanks again.
Sasha Posted September 4, 2007 Report Posted September 4, 2007 Yes, that list looks OK.LTC module is better to use because midi thru than midi activity indication.In SID V2 faders should be possible, but in that case you can`t save envelope presets into memory, so it is not so good idea.
sineSurfer Posted September 5, 2007 Author Report Posted September 5, 2007 Ok, I'm on the right track ;D, and I better forget about those those faders, thanks!.Now, can I build all but the LED matrix and everything will work just fine? I'm thinking about letting that for later... are those parameters editable via the menus?I'm sure all this has been answered before, so thanks a lot for doing it here too, i'll keep reading thru all posts and documents available to learn more.
Wilba Posted September 5, 2007 Report Posted September 5, 2007 Ok, I'm on the right track ;D, and I better forget about those those faders, thanks!.Definiately forget about faders for parameter controls like that, but they can be cool as configurable analog inputs which you can map to anything... i.e. pitch bend, LFO rate/depth etc.Now, can I build all but the LED matrix and everything will work just fine? I'm thinking about letting that for later... are those parameters editable via the menus?Yes, the modulation matrix is editable via the menu.
Goblinz Posted September 5, 2007 Report Posted September 5, 2007 Definiately forget about faders for parameter controls like that, but they can be cool as configurable analog inputs which you can map to anything... i.e. pitch bend, LFO rate/depth etc. Ooooh, this sounds interesting, I haven't been able to find anything about it though, can you put me in the right direction... It's be interesting to rig up something like a theremin to this.... Is this possible? G
Wilba Posted September 5, 2007 Report Posted September 5, 2007 Analog Control InputsMIDIbox SID V2 provides 8 analog inputs (5 currently used, 3 reserved for future features). They can be used to connect additional pots/faders or joysticks for direct sound control, but they could also be driven from analog signal generators. More info can be found in the Frontpanel chapter.
Goblinz Posted September 5, 2007 Report Posted September 5, 2007 ***hangs head in shame*** That's pretty much the only place I didn't look Thanks for the pointer. I think I may have actually deserved a slap round the face and an RTFM though! Any, I suppose I should stop hijacking this thread. G
sineSurfer Posted September 6, 2007 Author Report Posted September 6, 2007 Definiately forget about faders for parameter controls like that, but they can be cool as configurable analog inputs which you can map to anything... i.e. pitch bend, LFO rate/depth etc.cool, so not all is lost!... need to print that manual now. thanks Wilba, btw. your sid rocks!!!
sineSurfer Posted September 6, 2007 Author Report Posted September 6, 2007 About the LCD display, it seems that I can get this model locally:LCD display candidatecan I use it right out of the box?(I saw the LCD module part on the site, but I'm not that good on the technical side :-\)some more of those displays and their datasheets LCD displaysthanks!Update: I did my homework!, it is compatible as it uses KS0066 controller, acording to:hd44780_compatible
