Hello,
I'm in the middle of building my own Midibox DIY synth. Both SID and FM modules works fine, so I deciced to build them together.
My current config looks like this:
Midi In --> Core1 (for SID) --> MBLink --> Core2 (for FM) --> Midi Out
Almost everything works (ordinary midi messaged are processed well), except sysex messages. Core2 can be accessed fine with sysex, I can upload patches, firmware. Core1 does not work, when I try to reload firmware, I get "Received unexpected MIOS SysEx message = 00007E40020E0B00F7  expected = 00007E4001" message.
Core1 configured to MBLink forward point, device id 1, and Core2 configured to link endpoint and device id 2.
Am I missed something important?
Thanks.
Regards,
Gyurek
Hi Gyrurek,
the second core sends "0b" status core, which means: MIDI overrun.
It seems that the MBFM firmware loads the CPU already so much, that merging cannot be done this way :-(
If you've luck, it will work better when a "primitive patch" (which doesn't use the modulation features) is selcted.
