hi
i am going to put a midiman 2X2 in my next box, but i don t have one here right now.I need to know the way it looks like inside and in particular the measurements when it is out of its enclosure.Has anybody one of those? can you take a pic at its guts and take a few pictures?
thanks
simone
hi kris
you re my daily hero
please confirm this: the maximum height of the electronics is actually the height of the midi sockets plus the PCB thickness,right?
Also: when they say that it can also work as a stand alone MIDI hub, does it need to be powered with the USB anyway ?
Simone
it is powered via usb for using it with a computer and in stand alone with a thru mode switch that route the inA to outA and inB to outB without any power supply.
  hello cimo
        your right the maxium height is midi sockets plus pcb
        im not shure about the stand alone midi hub and powering i just power it from usb
  regards kris
of course, it work without usb....
from m-audio:
2-in/2-out MIDI interface
32 discrete MIDI input channels; 32 discrete MIDI output channels
bus-powered—requires no external power supply
compact and lightweight for mobile or desktop use
standalone mode allows basic throughput even when computer is off
