pilo Posted May 14, 2003 Posted May 14, 2003 hi!I found a new PIC18f programmer :http://members.naspa.net/djs/software/pic18f.htmlwhich is a plug on the parallel port... And the woftware works under linux.I think I can use it without any care?thanks!
pilo Posted May 14, 2003 Author Posted May 14, 2003 hi!I found a new PIC18f programmer :http://members.naspa.net/djs/software/pic18f.htmlwhich is a plug on the parallel port... And the woftware works under linux.I think I can use it without any care?thanks!
TK. Posted May 15, 2003 Posted May 15, 2003 Hi Pilo,the problem with this programmer is, that it uses the low-voltage programming mode and therefore allocates pin RB5, which - once the mode has been enabled - cannot be used for any other purpose anymore. Consequentialy you cannot drive a LCD module, which requires RB5 as data pin.Best Regards, Thorsten.
pilo Posted May 15, 2003 Author Posted May 15, 2003 hum... But, I put the pic on the programmer, then put it in the midibox... Because I use RB5 in the programmaing sequence then i can't use it anymore??!!?? Maybe I should download the PIC18F datasheet....I want to make a stand-alone programmer (not in the midibox)... ???
TK. Posted May 15, 2003 Posted May 15, 2003 Hi,Because I use RB5 in the programmaing sequence then i can't use it anymore??!!??yes!From the PIC18F452 datasheetThe High Voltage Programming mode is always available, regardless of the state of the LVP bit, by applying VIHH to the MCLR# pinWhile in low voltage ICSP mode, the RB5 pin can no longer be used as a general purpose I/O pin.Best Regards, Thorsten.
