RC Servo control
e-toy
well, I have read a lot of threads about PWM and stepper motors and so on, but I couldnt find an final answer that helps me to answer my next question.
I like to control some RC servos with the MB64. That means the DOUT have to output an PWM signal.
I'ts not really highspeed clocked ... every 20ms a pulse of 1ms (min. value) to 2 ms (max.value).
I have read that PWM needs very much performance, but I dont know if this relative slow PWM is also too much for an PIC (in the case that there are 4 to 16 such PWM needet). And finaly I have no idea how I could programm such a PWM "option"  ::).
someone tried this ?
any hints ?
Thanks
e-toy
Ahhh PWM... It's like the $64000 question around here lately!
There's a PWM peripheral on the PIC, has anyone aside from TK used it and feels like explaining it to us all? I've got a rough idea, so I'll step up and learn the rest if needed... But I don't want to reinvent the wheel if someone already knows ;)
Anyhow, that's just the one output, not 4-16, so I don't know if this is the right way to go for you e-toy.
any hints ?
Check this :
http://www.hobbyengineering.com/H1591.html
http://www.crownhill.co.uk/product.php?prod=1267
(looks very interesting, i ordered one!)
I plan to try it, but maybe only after my mbhp stepper motor driver :)
I have this document : http://www.roboter-teile.de/datasheets/sd20.pdf
can someone translate this to me :
Das ist der Einschaltzustand. Der Stellbereich geht von 1ms bis 2ms bei 1,5ms Mittelstellung
(entspricht der RC-Modellbau Spezifikation). Um in den Standard Modus zurückzukommen
(falls zuvor in den erweiterten Modus gegangen wurde), muss eine 0 (Null) in das Reg 21
geschrieben werden. Werte von 1 - 255 (0x01 - 0xff) im Reg 21 schalten in den Erweiterten
Modus.
I dont understand a german word, and google translator didn't help me much :(
Should i write something to register 21 before i can use standard mode ?  :-\
Hi Bill,
it sais:
This is the state when switched "on". Selectable values range from 1ms to 2ms (1.5ms middle) like the RC-model specification). When the extended Mode has been selected, you can switch back to standard mode by writing a 0 (zero) to register 21. Values from 1 - 255 (0x01 - 0xff) in register 21 switch to extended mode
Hope this helps ;)
Best,
Michael
