Echopraxia Posted October 9, 2007 Report Share Posted October 9, 2007 TK, on your MBSEQ 3.2 asm file, you mention "never change the origin". I want to change the din and douts shift register pinning so my cabling will be nice a straight inside my case. My question is which part do I change? Do I only change the SR# + pin# or do I move the function name to another line where the "correct" SR# + PIN# are? I basically want to have the track,pattern,layer and trigger dins to be on the first registers because all of those buttons are goinh to be on the left side of my case and my first din module is toward the left of the case aswell. I would hate to have a whole bunch of extra long cable inside the case. Quote Link to comment Share on other sites More sharing options...
ris8_allo_zen0 Posted October 9, 2007 Report Share Posted October 9, 2007 "Never change the origin" is referred to the "org" number in that row.You just need to edit the SR and pin numbers. It doesn't matter the order of the DIN/DOUT_ENTRYes.For the encoders, instead, the order is important. But again, if you just edit the numbers you won't get troubles.Greetings, RAZ Quote Link to comment Share on other sites More sharing options...
