Guest cjlargear Posted May 18, 2003 Posted May 18, 2003 HI everyone.;DI have two questions to ask1> It might seem stupid, but can I use trimpots instead of standard pots?I would like to gain the space, cause trimpots are smaller than the regular ones.2> Here in Greece I cannot find faders, what is the normal price for those and where could I get some of those????Thanks in advance for your replies.
pay_c Posted May 18, 2003 Posted May 18, 2003 1: Certainly. Also I really would consider using the standard pots, because: Theyre hard to destroy and just because of the space: If you built the pots to near to each other, you cant just turn one really fast, because, youll touch the others.2: There is a reeeaaaally broad bandwidth: From 1.50 (or even less at ebay) up to 20 Euros or more (like ALPS high quality faders).
uclaros Posted May 21, 2003 Posted May 21, 2003 Hi cjlargear!1) I agree with pay_c!2) In greece you can find basically 2 ypes of faders. Plastic ones for about 1.3euro and metallic ones for about 3 euros.The metallic ones are sliding so smooth you'll want to use them all day. I have used plastic ones for my MBHP but haven't tested them yet since there is a lot of wiring left to do...Check "contribution in greece" forum to see where you can buy them! Sthn athina exei o FANOS panw apo thn plateia kanigos.
