DIY recycled scroll wheel
Sasha
While I was digging the printer parts box I am collecting for CNC machine I would like to build I stumbled across these wheels that are originally used to drag the paper out of the tray. They are very soft and nice to touch. After some touching idea struck me. They would be very nice for scene scroll wheel for Ableton live controller or for tempo on Traktor.
pic 1
As the wheels had pretty sharp edges (even they feel soft) and old damaged surface, I needed o sand it down a little bit. I use screw and bolts to fix it into hand drilling machine. It is not must to be done that way, but it makes it easier to do it like this.
pic 2
To sand the knob evenly it is very important for wheel not to wobble so I used metal D shaft from old pot attached to the drilling machine.
pic 3
This is just for illustration. It is important to cut the pointer off the knob first and than proceed with sanding.
pic 4
I didnt actually trim this knob I got from MTE just for this purpose. I did that the other day in order to have thin pointerless knob. That is the reason it is black. This was just for testing. As you can see i trim the top too much so I got the that hole, which I wanted to plug with 3mm LED cap. It would look good.
1781_01_jpg4efdd2f969559e8b1c92e99f32ded
1783_02_jpg3fb5ed13afe8714a7e5d13ee50600
1785_03_jpgf99687dd719c4e8bc6a39e946c3d9
1787_04_jpg2de40e0d504f583cda7465979f958
pic 5
I got very lucky this DIY pointerless knob fits just right into the wheel hole with just enough preassure.  :)
pic 6
This is how final product looks like. When encoder is inserted it makes everithing even more secure. It stands on shaft very firmly. This wheel can be fixed on to "L" bracket and mount on panel.
I am very satisfied with the result and it was quick and fun Saturday morning project.
1789_05_jpg135007e7085979a7d5b41ce54c0e5
1791_06_jpgfac4ef5554f69012fe38d2f1d4e24
Hehehe I saw the pics before the text and knew it was you right away when I saw the recycling in action ;)
Hope it helps, the printer techs at work call them 'pickup wheels' :)
You may find more of other sizes inside the printer, certainly if it has a duplexer.
Sasha,
I use a long version for my drum finish roller. ;D
I think it may have actually been the "pickup wheel" from a copy machine though.
Keep up the good work on the knob burning. That dark one is resembling the Alesis 3630 knobs I'm fond of. (burn it down any more and you may be left with dust though ;))
George
Jidis, what is drum finish roller?
A big, heavy piece of crap that I built and used for about a day. ;D
It actually spins drum shells too. The xerox machine roller part just squashes the sheets of plastic finish onto the shells (with contact adhesive). If you use a small hand roller, you tend to get air bubbles in the plastic. It worked OK, but I haven't needed it much.
Take Care (and please post pics if you do any more "spin grinding").
George
