t_xen Posted November 19, 2007 Posted November 19, 2007 Hi all. :)I have constructed a MidiboxCV and need some help.Here's what I have for the power. I have the core powered by a 12v powersupply and is being ran through a 5v regulator into the Core Module. I have the CV firmware uploaded into the core and its operating normally. Since I was not able to obtain an AOUT_LC, I went ahead and etched my own board. ;DThe R-2R section comes within .5% tolerance.Instead of the rated 12v bipolar supply on the AOUT_LC, I have 2 batteries rigged to give a supply of +9v/-9v and ground to power it. I seem to have a problem with calibrating the thing to drive a linear VCO. could the batteries be an issue, possibly under powering the AOUT_LC? ???
t_xen Posted November 19, 2007 Author Posted November 19, 2007 Oh duh. :PRTFM.I changed the line "#define DEFAULT_AOUT_INTERFACE 1" to "#define DEFAULT_AOUT_INTERFACE 2".Recompiled and uploaded.Now it's behaving properly. I only get about 7.5 volts for the maximum output (prolly cuz I'm using 9v batteries), but that is fine since the linear VCO's I'm driving have an accuracy of only 5-6 octaves.Anyway it's getting late here in the Pacific NW, so I'm going to try it out on my synth tomorrow and see how it does.I'll post a pic here of the end result.thnx and good night. ;)
t_xen Posted November 20, 2007 Author Posted November 20, 2007 Here are the results.After attempts at calibrating, here's what I've got.I set the calibration minimum to 0v. then I set the maximum to 7v (9v battery powered).then when I select the 1v setting and set the output, I switch to 2v and I get 1.996v. I adjust to 2v and then switch to 4v. the multimeter reads 3.996v.Looks like it's falling flat, folks. :-\Apparently (I think I read this somewhere before) that the AOUT_LC isn't suitable for driving Linear VCOs because of the lack of accuracy, but should be fine for driving anything else that's analog. ::)I requested some samples from Maxim-IC for 2 MAX525's to attempt an AOUT, but I'm not gonna hold my breath.No images yet, I want this working before I post it. :)Here the image of the AOUT_LC I constructed.I don't have a drill to make the holes for the pins, so I just put the circuit on top and surface mounted all the parts. I used clippings from the resistors to make bridges that go over the traces. This took very steady hands. ;)I'll post an image of the AOUT in this thread after it's constructed.l8r 8)
t_xen Posted November 20, 2007 Author Posted November 20, 2007 Side note...........Since the AOUT_LC I constructed isn't accurate enough for diving linear VCOs, I'm going to use it in the MidiboxSID I constructed. I have a filter board I've constructed. CEM filters seem to be a little expensive and hard to come by, but the filter I created is directly off the filter from the Soundlab Mini-synth section (the analog synth I'm attempting to drive with the MBHP_CV).I'll post a PIC of the filter in the SID forum. ;D
TK. Posted November 20, 2007 Posted November 20, 2007 Are the OP amps directly supplied by the batteries - so, isn't there a voltage regulation? In such a case it's very unlikely to get stable results.Best Regards, Thorsten.
t_xen Posted December 3, 2007 Author Posted December 3, 2007 yea, I was directly supplying the opamp with the batteries. Oh well, the board is no longer in the case I've created for the Midibox_CV. It's now in my 4xSID, controlling a filter board from RJW Soft. I've just etched an AOUT module since I was able to aquire 2 MAX525s and a MAX6007B shunt as free samples from Maxim IC. This would be better anyhow since I have an analog synth with 2 VCOs, 2 VCO modules, and 3 VCFs. Should be the best route since I have the beginnings of a modular synth. :)Thanks for the info, TK. :D
