flamtronic Posted November 27, 2007 Report Posted November 27, 2007 Hello:Will drum pad input into the pot design cause problems with the pad input being a spike, and the usual input from the intended pots being a continual voltage?For background, I am interested in building a midi box to accept info from drum pads. I own a Simmons SDX, which is too fragile to perform out with. The pads output a voltage for velocity and also postion of strike. I have (hopefully accurate) schematics for the input circuitry ending in a 4051, which should be the start of the input for the midibox. I would like to split the input to one regular note on/velocity midi signal, and one cc representing the position. This would then leave the box to some sampling software. As I know nothing of C programming or assembler, I was hoping to use the available MIOS for the box.Thanks for any advice you can give.John Quote
TK. Posted November 28, 2007 Report Posted November 28, 2007 Hi,crosstalk between analog inputs shouldn't be a problem so long each individual cable connected to an analog input (CORE:J5) is shielded to ground.Best Regards, Thorsten. Quote
