I've just finished my SID Synthetiser and it rocks !!! Thanks Thorsen for sharing such a great DIY project with all of us !!!
By the way, I have also built the minimal control surface, so-called step A. I guess I will not go further with the control surface (B, C & D) as this one is already flexible enough for my needs.
However, I noticed a strange behaviour with the encoder (I'm using the Mouser ENC160-24p as recommended). When I'm editing some values (let's say the LFO rate), one detent on the encoder matches with one increment/decrement of the value, which is perfect. When I'm editing some other values (let's say the filter resonance) the value can get incremented/decremented only by 8 (but matching the number of detents :8). Also when using the encoder to move in the menu, I need 4 detents.....
Could someone confirm if this is "normal" or not as I had some troubles to indentify which pins of the encoder was A, B & C.
Also I noticed that I don't have access to the Rec waveform for the Oscillator.  Is it another "encoder problem" or something missing in the minimum control surface firmware ???
Thanks for your help,
Richard
Richard
Hi Richard,
the firmware changes the "encoder speed" depending on the value range (max value). Some values with a short range require more detents than others, in order to allow a precise control. So, this effect is ok.
There are also some parameters like the oscillator ADSR or the filter cutoff/resonance, which are only 4 bit wide (limited by the SID chip itself). Thats the reason why these values can only be incremented/decremented by 8
But regarding the Rectangle waveform I'm unsure ("Pul" for Pulse should be displayed). If some inc/dec pulses from the encoder are missing
(see also http://www.ucapps.de/mios/mios_encoder_modes.gif), you either have to change the connections (see the schematics under Concepts->MBHP->DIN) or the encoder mode in the application setup (-> mios_tables.inc)
Hope this helps - have fun with the SID! :)
Hi Richard,
