DragonMaster Posted December 15, 2007 Posted December 15, 2007 Hi all, someone on the French forums needs to build a MIDI keyboard using 108 keys with velocity. So far, it looks like SPDT switches will be used. What would be the best way to connect this to a MIDIbox?There's this way : http://www.midibox.org/forum/index.php?topic=5835.0but it only supports 63 notes. (Two cores, eight DINX4s and a LOT of wire...)I thought about using a matrix, but there's nothing so far with velocity support and I wonder if the keys would be scanned fast enough. So far it looks like the keyboard will just have a power input, keys and a MIDI output. Any ideas?
Durisian Posted December 16, 2007 Posted December 16, 2007 QBAS made a velocity sensitive scan matrix for a keyboard....http://www.midibox.org/forum/index.php?topic=6386.15The 16x16 matrix is big enough, but I think he only made 12x11 as velocity sensitive.Would be a good starting point if you can program in asm.
DragonMaster Posted December 16, 2007 Author Posted December 16, 2007 if you can program in asm.Nope, only TRS-80 Color Basic, DOS batch and once modded a program made in Tcl/Tk.I've never got to build my Microchip ICD2 clone to start learning ASM... I have all the parts, but my LaserJet IIP printer died last year (I bought a new scanner motor last week, should be getting it soon! -with COD brokerage fees... >:()I don't think I'll learn ASM for someone else if I have other priorities during the next month(Off school from Dec 21st to Jan 21st) :1. Buy and program Flash ROMs for my Kawai K4r V1.4 / K4m V1.4 / K5 V1.3 / K5m V1.2 firmware upgrade group order.2. Buy 8x 6582 reserved SIDs from Wilba.3. Fix the #!$@;* sump pump check valve.4. Fix the noisy ADC stage in my Fostex DAT deck I bought 1-2 months ago.5. Fix my laser printer and start to build some PCBs for projects on standby.... (+ two mono tube amps to restore, my Gainclone to get working properly, finish the speakers I started to build in 2004, repairing two amps with little-annoying problems, get an analog oscilloscope-> align three cassette decks and a few tuners, etc.) ... then if everything goes well, in a few years I'll build the ICD2 and start working on MIDIboxes... -> That's going to be in years! (In the mean time, I get some parts while they're still available)
QBAS Posted December 16, 2007 Posted December 16, 2007 SPDT switches are different than this one used in standard keyboard, so code that I use is not compatible.
DragonMaster Posted December 16, 2007 Author Posted December 16, 2007 SPDT switches are different than this one used in standard keyboard, so code that I use is not compatible.I see... The person might build a Off-(On1)-(On2) switch system though, that would be closer to a usual keyboard.Still... not sure of which switch type will be used, so there are a few steps to do before thinking about software and MIDIbox hardware...
