creatorlars Posted December 27, 2007 Posted December 27, 2007 I got all 8 CV outputs of my SEQ working, and am now trying to get the 8 gates from J5 of the core working as well. Gate 6, only, seems to work perfectly, but the rest appear to have issues (wiring and connections are triple-checked and all good, the appropriate line in the code has been enabled.) I am testing with my multimeter for voltage at the J5 outputs and sending MIDI note signals from MIOS Studio, routed to the appropriate AOUT channel. With Gate 6, I get a steady +5v while holding down a MIDI note, as expected. With all other gates, I register /some/ fluctuation of voltage, but it is a quick random jump from 0v to 0.5-1v. I've tried grounding the two gate outputs from the AOUT module (which are working correctly), but that hasn't seemed to help. I'm kind of at a loss here -- could there be other issues I'm unaware of? A bad PIC seems unlikely, but I can't think of what else to try. Any help is kindly appreciated.
Sasha Posted December 27, 2007 Posted December 27, 2007 I`m not sure how MIDI signals are treated by SEQ when coming from MIOS studio, but gates are pulsed with 1ms pulse when coming from SEQ. That is too short for standard meter to measure, I think you need an oscilloscope. But as you say you are having steady 5V on gate 6 I might be wrong. :/
creatorlars Posted December 27, 2007 Author Posted December 27, 2007 Just double checked this again, and I'm getting the same result out of ports 6, 7 & 8... weird. Gonna keep tweaking and see what happens.
