uclaros Posted May 27, 2003 Report Share Posted May 27, 2003 I've just finished my midibox 32pots/32buttons w/ midibox64 f/w and it seems to work like a charm!All pots say 0-127 , buttons working, lcd ok, bankstick can be read -formated-written, midi out led lights.BUTwhen I plug it on my PC with MIDIOX and move a pot or button I get MIDI TIME OUT!WHATS UP??I get the same after sending a few midi commands to the midibox too!The same error I get if I plug the MB on my POD2 so it's not my PC faulty...Midiox's monitor shows that it recieves one or two events followed by a F8 :timing clock or FC :stop , just before the crash ( some other times it's a FD :undefined or FF :system reset) Can somebody help me before I start building a new Core?? Thanks in advance!uclaros Quote Link to comment Share on other sites More sharing options...
uclaros Posted May 27, 2003 Author Report Share Posted May 27, 2003 Ok, I unpluged the input cable from the MB so it only sends data.What I realized is that when a pot is moved , MB sends pretty random data. It's not totaly random , because every second command is an FF or F8 or something else starting with F!Any Ideas? Quote Link to comment Share on other sites More sharing options...
uclaros Posted May 28, 2003 Author Report Share Posted May 28, 2003 Ok again, I swaped the core with my 18f one and works perfectly!Now I 've got to see what's wrong with the first core.... Quote Link to comment Share on other sites More sharing options...
TK. Posted May 30, 2003 Report Share Posted May 30, 2003 Hi uclaros,Maybe this time out is caused by a feedback loop.If the "automatically attach Inputs to Outputs" option is enabled in MIDI-Ox, such feedback loops will be created without informing the user. This option should be disabled like shown here:Thereafter deselect all output devices and select them again, or open the port mapping and delete all input portsBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
uclaros Posted June 3, 2003 Author Report Share Posted June 3, 2003 Thanks for your reply TK, but I don't think the problem is caused by MIDI-Ox because I get the same error when I connect both midi in and midi out to my POD-guitar amp modeler. The problem is definetly on the core module since after swapping it with another everything is ok!Furthermore, if I conect only MB's midi out to the pc I get those wierd Fx midi messages after every single other one transmitted!Since everything works now, I have all the time I need to debug this myself!Thnks again! Quote Link to comment Share on other sites More sharing options...
