cimo Posted January 16, 2008 Posted January 16, 2008 so i am all set up to build a little application, i am working on OSX and everything seems to be ok, SDCC, Gputils, X-Code.I modified main.c and even got a successful build but there is no syx or hex output.Active target set to "MyProject".what am i missing?simone
audiocommander Posted January 16, 2008 Posted January 16, 2008 Hi Simone,first question:have you set up the targets like described here:http://www.midibox.org/dokuwiki/how_to_use_xcode2_as_ide_on_a_mac#about_targets_and_makefiles1. Target "Makefile"2. Target "MyProject"second question:do the perl scripts in the "/skeleton/tools" directory have the right permissions? Means, they have to be allowed "executable". You can either do this by calling [tt]chmod[/tt] in the terminal or (easier) with the FTP-client of your choice (every FTP client has some infopanel where file-rights can be set easily)Best,Michael
cimo Posted January 16, 2008 Author Posted January 16, 2008 hiyes it was all ok but i ve found the problem there was a missing line in the makefile script for the project, due to a copy n paste at 5am in the morning! now i get errors but just because i modified the code and something is wrong.thanks!!now i ll try to create this little app. (it was in the assembler forum before)4 buttons with leds1 pot (pedali want the 4 buttons to switch among 4 different parameters (or midi channels) of the pot and having the leds for visual feedbacksimone
cimo Posted January 16, 2008 Author Posted January 16, 2008 yeppaaaso far the buttons are working and the pot as well, very easybut when i add this code///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a complete MIDI event has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedEvnt( unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { // a note event provides 128 different note values (0..127) // in this simple example, each note sets an individual pin // for DOUT pin numbers, see also this documentation: // http://www.ucapps.de/mios/mios_pin_list.txt if( evnt0 == 0x80 || evnt0 == 0x90 ) { // 90 xx 00 is the same like a note off event! // (-> http://www.borg.com/~jglatt/tech/midispec.htm) if( evnt0 == 0x80 || evnt2 == 0x00 ) { // Note Off MIOS_DOUT_PinSet(pin, 0); } else { // Note On MIOS_DOUT_PinSet(pin, 1); } } }i get these errorsBuilding target “Pedal†of project “Pedal†with configuration “Debug†— (13 errors) cd /Users/simonemarin/Desktop/Pedal setenv ACTION build setenv ALWAYS_SEARCH_USER_PATHS YES setenv APPLE_INTERNAL_DEVELOPER_DIR /AppleInternal/Developer setenv APPLE_INTERNAL_DIR /AppleInternal setenv APPLE_INTERNAL_DOCUMENTATION_DIR /AppleInternal/Documentation setenv APPLE_INTERNAL_LIBRARY_DIR /AppleInternal/Library setenv APPLE_INTERNAL_TOOLS /AppleInternal/Developer/Tools setenv ARCHS ppc setenv BUILD_COMPONENTS "headers build" setenv BUILD_DIR /Users/simonemarin/Desktop/Pedal/build setenv BUILD_ROOT /Users/simonemarin/Desktop/Pedal/build setenv BUILD_STYLE Debug setenv BUILD_VARIANTS normal setenv BUILT_PRODUCTS_DIR /Users/simonemarin/Desktop/Pedal/build/Debug setenv CACHE_ROOT /Library/Caches/com.apple.Xcode.501 setenv CCHROOT /Library/Caches/com.apple.Xcode.501 setenv CHMOD /bin/chmod setenv CHOWN /usr/sbin/chown setenv CLASS_FILE_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/JavaClasses setenv CLEAN_PRECOMPS YES setenv CLONE_HEADERS NO setenv CONFIGURATION Debug setenv CONFIGURATION_BUILD_DIR /Users/simonemarin/Desktop/Pedal/build/Debug setenv CONFIGURATION_TEMP_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug setenv COPY_PHASE_STRIP NO setenv COPY_RESOURCES_FROM_STATIC_FRAMEWORKS YES setenv CP /bin/cp setenv CURRENT_ARCH ppc setenv CURRENT_VARIANT normal setenv DEBUGGING_SYMBOLS YES setenv DEBUG_INFORMATION_FORMAT stabs setenv DEPLOYMENT_LOCATION NO setenv DERIVED_FILES_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/DerivedSources setenv DERIVED_FILE_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/DerivedSources setenv DERIVED_SOURCES_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/DerivedSources setenv DEVELOPMENT_LANGUAGE English setenv DSTROOT /tmp/Pedal.dst setenv DWARF_DSYM_FILE_NAME .dSYM setenv DWARF_DSYM_FOLDER_PATH /Users/simonemarin/Desktop/Pedal/build/Debug setenv ENABLE_HEADER_DEPENDENCIES YES setenv EXCLUDED_RECURSIVE_SEARCH_PATH_SUBDIRECTORIES "*.nib *.lproj *.framework *.gch (*) CVS .svn *.xcodeproj *.xcode *.pbproj *.pbxproj" setenv FIXED_FILES_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/FixedFiles setenv FRAMEWORK_VERSION A setenv GCC_DYNAMIC_NO_PIC NO setenv GCC_ENABLE_AUTO_PCH NO setenv GCC_GENERATE_DEBUGGING_SYMBOLS YES setenv GCC_OPTIMIZATION_LEVEL 0 setenv GCC_PFE_FILE_C_DIALECTS "c objective-c c++ objective-c++" setenv GCC_TREAT_WARNINGS_AS_ERRORS NO setenv GCC_VERSION 4.0 setenv GENERATE_PKGINFO_FILE NO setenv GENERATE_PROFILING_CODE NO setenv GROUP simonemarin setenv HEADERMAP_INCLUDES_FLAT_ENTRIES_FOR_TARGET_BEING_BUILT YES setenv HEADERMAP_INCLUDES_FRAMEWORK_ENTRIES_FOR_ALL_PRODUCT_TYPES YES setenv HEADERMAP_INCLUDES_NONPUBLIC_NONPRIVATE_HEADERS YES setenv HEADERMAP_INCLUDES_PROJECT_HEADERS YES setenv INFOPLIST_EXPAND_BUILD_SETTINGS YES setenv INSTALL_DIR /tmp/Pedal.dst setenv INSTALL_GROUP simonemarin setenv INSTALL_MODE_FLAG a-w,a+rX setenv INSTALL_OWNER simonemarin setenv INSTALL_ROOT /tmp/Pedal.dst setenv JAVAC_DEFAULT_FLAGS "-J-Xms64m -J-XX:NewSize=4M -J-Dfile.encoding=UTF8" setenv JAVA_APP_STUB /System/Library/Frameworks/JavaVM.framework/Resources/MacOS/JavaApplicationStub setenv JAVA_ARCHIVE_CLASSES YES setenv JAVA_ARCHIVE_TYPE JAR setenv JAVA_COMPILER /usr/bin/javac setenv JAVA_FRAMEWORK_RESOURCES_DIRS Resources setenv JAVA_JAR_FLAGS cv setenv JAVA_SOURCE_SUBDIR . setenv JAVA_USE_DEPENDENCIES YES setenv JAVA_ZIP_FLAGS -urg setenv JIKES_DEFAULT_FLAGS "+E +OLDCSO" setenv LEX /usr/bin/lex setenv LINK_FILE_LIST_normal_ppc setenv LOCAL_ADMIN_APPS_DIR /Applications/Utilities setenv LOCAL_APPS_DIR /Applications setenv LOCAL_DEVELOPER_DIR /Library/Developer setenv LOCAL_LIBRARY_DIR /Library setenv MAC_OS_X_VERSION_ACTUAL 1041 setenv MAC_OS_X_VERSION_MAJOR 1040 setenv NATIVE_ARCH ppc setenv NATIVE_ARCH_32_BIT ppc setenv NATIVE_ARCH_64_BIT ppc64 setenv NATIVE_ARCH_ACTUAL ppc setenv NO_COMMON YES setenv OBJECT_FILE_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/Objects setenv OBJECT_FILE_DIR_normal /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/Objects-normal setenv OBJROOT /Users/simonemarin/Desktop/Pedal/build setenv OPTIMIZATION_LEVEL 0 setenv OS MACOS setenv OSAC /usr/bin/osacompile setenv PASCAL_STRINGS YES setenv PATH_PREFIXES_EXCLUDED_FROM_HEADER_DEPENDENCIES "/usr/include /usr/local/include /System/Library/Frameworks /System/Library/PrivateFrameworks /Developer/Headers" setenv PKGINFO_FILE_PATH /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/PkgInfo setenv PREBINDING YES setenv PRECOMP_DESTINATION_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/PrefixHeaders setenv PRODUCT_NAME Pedal setenv PRODUCT_SETTINGS_PATH setenv PROJECT Pedal setenv PROJECT_DERIVED_FILE_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/DerivedSources setenv PROJECT_DIR /Users/simonemarin/Desktop/Pedal setenv PROJECT_FILE_PATH /Users/simonemarin/Desktop/Pedal/Pedal.xcodeproj setenv PROJECT_NAME Pedal setenv PROJECT_TEMP_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build setenv RECURSIVE_SEARCH_PATHS_FOLLOW_SYMLINKS YES setenv REMOVE_CVS_FROM_RESOURCES YES setenv REMOVE_SVN_FROM_RESOURCES YES setenv REZ_COLLECTOR_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/ResourceManagerResources setenv REZ_OBJECTS_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/ResourceManagerResources/Objects setenv SCRIPT_INPUT_FILE_COUNT 0 setenv SCRIPT_OUTPUT_FILE_COUNT 0 setenv SDKROOT setenv SED /usr/bin/sed setenv SET_DIR_MODE_OWNER_GROUP YES setenv SET_FILE_MODE_OWNER_GROUP NO setenv SHARED_DERIVED_FILE_DIR /Users/simonemarin/Desktop/Pedal/build/Debug/DerivedSources setenv SHARED_PRECOMPS_DIR /Library/Caches/com.apple.Xcode.501/SharedPrecompiledHeaders setenv SKIP_INSTALL YES setenv SOURCE_ROOT /Users/simonemarin/Desktop/Pedal setenv SRCROOT /Users/simonemarin/Desktop/Pedal setenv STRIP_INSTALLED_PRODUCT YES setenv SYMBOL_REPOSITORY_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/SymbolRepositories setenv SYMROOT /Users/simonemarin/Desktop/Pedal/build setenv SYSTEM_ADMIN_APPS_DIR /Applications/Utilities setenv SYSTEM_APPS_DIR /Applications setenv SYSTEM_CORE_SERVICES_DIR /System/Library/CoreServices setenv SYSTEM_DEMOS_DIR /Applications/Extras setenv SYSTEM_DEVELOPER_APPS_DIR /Developer/Applications setenv SYSTEM_DEVELOPER_DEMOS_DIR "/Developer/Applications/Utilities/Built Examples" setenv SYSTEM_DEVELOPER_DIR /Developer setenv SYSTEM_DEVELOPER_DOC_DIR "/Developer/ADC Reference Library" setenv SYSTEM_DEVELOPER_GRAPHICS_TOOLS_DIR "/Developer/Applications/Graphics Tools" setenv SYSTEM_DEVELOPER_JAVA_TOOLS_DIR "/Developer/Applications/Java Tools" setenv SYSTEM_DEVELOPER_PERFORMANCE_TOOLS_DIR "/Developer/Applications/Performance Tools" setenv SYSTEM_DEVELOPER_RELEASENOTES_DIR "/Developer/ADC Reference Library/releasenotes" setenv SYSTEM_DEVELOPER_TOOLS /Developer/Tools setenv SYSTEM_DEVELOPER_TOOLS_DOC_DIR "/Developer/ADC Reference Library/documentation/DeveloperTools" setenv SYSTEM_DEVELOPER_TOOLS_RELEASENOTES_DIR "/Developer/ADC Reference Library/releasenotes/DeveloperTools" setenv SYSTEM_DEVELOPER_UTILITIES_DIR /Developer/Applications/Utilities setenv SYSTEM_DOCUMENTATION_DIR /Library/Documentation setenv SYSTEM_LIBRARY_DIR /System/Library setenv TARGETNAME Pedal setenv TARGET_BUILD_DIR /Users/simonemarin/Desktop/Pedal/build/Debug setenv TARGET_NAME Pedal setenv TARGET_TEMP_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build setenv TEMP_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build setenv TEMP_FILES_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build setenv TEMP_FILE_DIR /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build setenv TEMP_ROOT /Users/simonemarin/Desktop/Pedal/build setenv UID 501 setenv UNSTRIPPED_PRODUCT NO setenv USER simonemarin setenv USER_APPS_DIR /Users/simonemarin/Applications setenv USER_LIBRARY_DIR /Users/simonemarin/Library setenv USE_DYNAMIC_NO_PIC YES setenv VALID_ARCHS "m68k i386 sparc hppa ppc ppc7400 ppc970 ppc64 x86_64" setenv VERBOSE_PBXCP NO setenv VERSION_INFO_BUILDER simonemarin setenv VERSION_INFO_STRING "\"@(#)PROGRAM:Pedal PROJECT:Pedal- DEVELOPER:simonemarin BUILT:\" __DATE__ \" \" __TIME__ \"\"" setenv XCODE_APP_SUPPORT_DIR "/Library/Application Support/Apple/Developer Tools" setenv XCODE_VERSION_ACTUAL 0241 setenv XCODE_VERSION_MAJOR 0200 setenv YACC /usr/bin/yacc /bin/sh -c /Users/simonemarin/Desktop/Pedal/build/Pedal.build/Debug/Pedal.build/Script-DBB5DA7B0D3E3865006B57C5.shsdcc -S -mpic16 -p18F452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector -I. -DDEBUG_MODE=0 main.c -o _output/main.asmProcessor: 18F452main.c:91: error 20: Undefined identifier 'pin'main.c:91: error 20: Undefined identifier 'pin'main.c:96: error 20: Undefined identifier 'pin'main.c:96: error 20: Undefined identifier 'pin'-:0: error 103: code not generated for 'MPROC_NotifyReceivedEvnt' due to previous errorsmain.c:108: error 103: code not generated for 'MPROC_NotifyFoundEvent' due to previous errorsmain.c:116: error 103: code not generated for 'MPROC_NotifyTimeout' due to previous errorsmain.c:123: error 103: code not generated for 'MPROC_NotifyReceivedByte' due to previous errorsmain.c:130: error 103: code not generated for 'SR_Service_Prepare' due to previous errorsmain.c:137: error 103: code not generated for 'SR_Service_Finish' due to previous errorsmain.c:147: error 103: code not generated for 'DIN_NotifyToggle' due to previous errorsmain.c:158: error 103: code not generated for 'ENC_NotifyChange' due to previous errorsmain.c:168: error 103: code not generated for 'AIN_NotifyChange' due to previous errorsmake: *** [_output/main.asm] Error 1 main.c:91: error 20: Undefined identifier 'pin' main.c:91: error 20: Undefined identifier 'pin' main.c:96: error 20: Undefined identifier 'pin' main.c:96: error 20: Undefined identifier 'pin' -:0: error 103: code not generated for 'MPROC_NotifyReceivedEvnt' due to previous errors main.c:108: error 103: code not generated for 'MPROC_NotifyFoundEvent' due to previous errors main.c:116: error 103: code not generated for 'MPROC_NotifyTimeout' due to previous errors main.c:123: error 103: code not generated for 'MPROC_NotifyReceivedByte' due to previous errors main.c:130: error 103: code not generated for 'SR_Service_Prepare' due to previous errors main.c:137: error 103: code not generated for 'SR_Service_Finish' due to previous errors main.c:147: error 103: code not generated for 'DIN_NotifyToggle' due to previous errors main.c:158: error 103: code not generated for 'ENC_NotifyChange' due to previous errors main.c:168: error 103: code not generated for 'AIN_NotifyChange' due to previous errorsBuild succeeded (13 errors)
bugfight Posted January 16, 2008 Posted January 16, 2008 ...i get these errors...i don't know the mac setup, but it looks like you have a java compiler selected.build the project without modifying it first...
bugfight Posted January 16, 2008 Posted January 16, 2008 also you haven't declared the variable "pin"
audiocommander Posted January 16, 2008 Posted January 16, 2008 you can ignore the Xcode internal [tt]sentenv[/tt] stuff, but bugfight is of course right about the "pin" variable.main.c:91: error 20: Undefined identifier 'pin'
cimo Posted January 16, 2008 Author Posted January 16, 2008 hiAC i ve spent the last 2 hours with Jimp in the.. i ve spent the last 2 hours with BugFight in the chat, he was so kind to guide me on a step to step techno-progressive learning curve that led me to have:-in the first phase all 4 buttons to send MIDI notes and leds to listen to the feedback-then we moved to assign a variable to the pot CC and change the variable with the buttons, light was added in the 7th daynow the TODO isusing a single button to change among, let s say 4 or 6 different CC for the pot, with 4 or 6 leds to visualize the status,keeping the other 3 buttons as normal NOTE ON/OFFi also need to scale and offset the pot, i am trying to figure out an hardware solution, hardware as modify the pot itself not as a circuitry, but if i fail i ll have to do it in the software.thanks for your help guyssimone
Durisian Posted January 16, 2008 Posted January 16, 2008 Hi CimoHave you checked out TK's C examples: http://www.ucapps.de/mios_c.htmlThere's some code snippets here you might find useful. Such a scaling pot values.Cheers!
cimo Posted January 16, 2008 Author Posted January 16, 2008 hiyes i ve checked the examples but i can t find the offset code, i think i will have a look at the ACsensorizer
