Insilentio Posted May 27, 2003 Report Posted May 27, 2003 Hallo,Is It possible to use a 4x 16 display? ???Thanx, Insilentio
pay_c Posted May 28, 2003 Report Posted May 28, 2003 Nope, not at the moment. If you use it, you will only see weird stuff (tried it out). Nothing to do there...There should come up a new version of the midimon to make it compatible with MIOS. And as MIOS is compatible to all LCDs (or nearly all), there you will be able to use also a 16x4.But as TK is more than busy at the moment (THNX for that Step B SID !!!!!!!!! God bless MIOS&MBs) it´s likely to be a long time until a upgrade for Midimon will come out.You can also read my thread about problems with the Midimon, there is more bout this. Just search for me & Midimon.
Insilentio Posted May 28, 2003 Author Report Posted May 28, 2003 Thank you very much.that's all i needed to know. ;D
