toxictv101 Posted January 30, 2008 Posted January 30, 2008 hi,is it possible to use the j5 pin as Analog to Digital converter for my custom C apps.tks.
seppoman Posted January 30, 2008 Posted January 30, 2008 wrong link, bill - he asked for Ain not Din :)the pins on J5 in fact are the A/D converter inputs. the AIN board just gives more inputs. So there should be no problem with using J5 without AIN board.S
toxictv101 Posted February 11, 2008 Author Posted February 11, 2008 but is there a initialisation port procedure ?and what is the name of the variable that get the value in ?
toxictv101 Posted February 11, 2008 Author Posted February 11, 2008 instead it would be realy cool.if i can use the j5 as Analog output ????anyone got experience with it ?
bill Posted February 11, 2008 Posted February 11, 2008 but is there a initialisation port procedure ?and what is the name of the variable that get the value in ?http://ucapps.de/mios_c_send_ain.htmlet voila !
seppoman Posted February 11, 2008 Posted February 11, 2008 instead it would be realy cool.if i can use the j5 as Analog output ????That's not possible. The PIC has an A->D converter but no D->A. There's no way to avoid building an AOUT module, as the topic is "cheap", you probably want the AOUT_LC which can be built for max 10 Euros.S
