wrong link, bill - he asked for Ain not Din :)
the pins on J5 in fact are the A/D converter inputs. the AIN board just gives more inputs. So there should be no problem with using J5 without AIN board.
S
instead it would be realy cool.
if i can use the j5 as Analog output ????
That's not possible. The PIC has an A->D converter but no D->A. There's no way to avoid building an AOUT module, as the topic is "cheap", you probably want the AOUT_LC which can be built for max 10 Euros.
S
