midibox programmation through the midi_router ?
fabricio
Yes, it's even possible with MIOS Studio (and this is the recommented solution due to robustness) - most of my MIDIboxes are connected to it, and I change firmwares at least once a week ;)
A bidirectional connection (MIDI In/Out passed through router) is required, and the router should get a dedicated MIOS Device ID (I'm using 0x7f). The device ID can be modified with the "change_id" application
Best Regards, Thorsten,.
thank you tk. No problem. MIOS Studio is ok through the router.
I want to thankyou for all your work for midibox.
i have make :
a midi bass pedal
a floorboard for guitar(looper)
a midi clock
and finally the router
with this system.
all this midibox have unique function(programmation in c)
i thank you very much !!
