MBSEQ MIDIOUT Fix
like at 3.3 v midi devices.
Schrabikus Midibox progress
· 73 images
  • 73 images
  • 99 image comments
TK.
Posted
Note: it seems that this modification is only required for MIDI devices which don't comply to the MIDI specification!
Usually the MIDI IN port of a device has to work correctly when the current through the MIDI wire is at least 5 mA.
3.3V / (3 * 220 Ohm) = 5 mA
norbim1
Posted
I think, that the opto LED opening voltage is missing form the equation....It's 1.3-1.5 V typ.
In case of 6N138 at the receiver side, the 3.3V supply cannot cause any problem.
But it's problematic if you use 6N136 as suggested somewhere. I've some bad experience.....
