Triffki
46 -
Everything posted by Triffki
MIOS programming with Xcode 2 on a Mac (OSX)
Triffki replied to Rowan's topic in MIOS programming (C)
Hey only just found this thread. I get the following error when building the skeleton app: make: execvp: /usr/local/bin: Permission denied Whereabouts in the shell script do I give execution rights to /usr/local/bin? It's also worth adding that although I've been following the tutorial on http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_xcode2_as_ide_on_a_mac I've skipped the makefile target phase, partly because there are some discrepancies between versions of the SDCC skeleton. For one, the file MAKEFILE.SPEC does not exist in the newest version. Cheers -
Thanks for the advice. I've made some progress, managed to get up to the application building stage now. I get this error when trying to build: "sh: /mios-gpasm: No such file or directory" I've checked that sdcc and gpasm are up and running by typing "sdcc -v" etc. in Terminal. My sdcc is version is 2.6, and gpasm is 0.13.4 I've also checked the usr/local/bin folder to check gpasm and sdcc are in there, which they are Any advice would be appreciated I'm running Xcode 3 by the way
Hi all, I've been following the tutorial here: http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_xcode2_as_ide_on_a_mac to set up Xcode 3. I got as far as creating a new project and then I got lost. I've downloaded mios_base_v1_1 from the downloads section on ucApps and found the SDCC skeleton files within it under 'apps'. Am I supposed to drag these files into the new project in Xcode? Also, the tutorial mentions the MAKEFILE.SPEC but I could not find this within mios_base_v1_1 Thanks
I can't seem to download the SDCC_skeleton files from the SVN repository. I can view the contents of the files on my browser, however
Ok I'll give that a go, thanks for the advice. Conveniently enough, I just started learning C at Uni
Yes the very same, thanks for clearing that up. I'll wait for the GM5 then. In the meantime, I've been searching the forums for firmware tips. I've just installed Xcode, SDCC and GPUtils on my mac, and downloaded the MIDIbox128 app files. As far as I can tell, the only bit of of editing I'm going to have to do before uploading it to the core is to change the number of DOUT modules from 4 to 3 and specify which inputs on the DIN modules are encoders. Which .c files do I need to make changes in?
I Finally got round to switching the unit on for the first time. Had a few issues with power rails to start off with but managed to fix them, so I'm sure each module is now getting the required 5V supply. I connected the PIC core (preprogrammed with MIOS) to my Mac using a cheap USB to MIDI cable (the final unit will house a USB GM5 chip once the latest bulk order goes through), and opened the MIDI studio application. To start with, my Mac detected the link and showed it as having 2 ports; one with input/output, the other with just output. I opened up MIOS which also detected the link, but it gave an error: 'Core not responding' or something similar. After resetting the unit however neither MIDI studio or MIOS detect any link. Am I wasting my time trying to talk to the unit with the cheap cable, and should I just wait for the GM5 which I assume is more reliable? My box is an augmented MIDIbox64, so I know I'll have to do some code editing at some point point to get it to work. Could someone please point me in the right direction of a tutorial or something to make this slightly less daunting for a programming novice? Even just a list of what I need download from the uCApps database would be a huge help . Thanks
From the album: Triffki Midibox
Ok, I've managed to sort the pcb out, and all the parts are currently on order. Just need to order the circuit modules now. However, I'm still torn as to whether to go for the old PIC based MIOS8 approach or the snazzy new LPC17. I understand there have been numerous updates to the new MIOS2 in the past few months, and I would feel more comfortable going for the newer hardware. Would this be overkill though? All I'm essentially trying to do is send and recieve MIDI signals from Traktor. Would the fact that my project contains a fairly odd selection of modules (2 x AIN, 4 x DIN, 3 x DOUT) tip the balance in one method's favour?
Been a busy few months, but I've finally managed to finalise a panel layout (image below) and pcb to mount underneath. I'm in the process of laying out tracks on a single sided pcb at the moment, but its proving ridiculously time consuming due to the limited space at my disposal (effectively 128 buttons, 96 LEDs and 64 pots on an area the size of an A4 sheet). Would it be a bad idea to connect all the ground lines together on the pcb rather than having each one connected individually on the respective AIN/DIN/DOUT modules? This would probably make the task a little bit easier. I know that linking digital and analog ground is generally a bad idea, but surely this won't be a problem so long as I isolate them. I'm using DesignSpark PCB from RS to draw the circuit. Does anyone know if theres a way to add a plain hole to the design i.e. one with no copper lining?
Thanks a lot for your help. Is there a recommended limit on the number of DIN modules for a single core? I'm thinking I may need up to 3
Hi all I've wanted to get stuck into building a Midi controller for a few months now, and it looks like the Midibox64 is my safest bet. A few long sessions of browsing through uCApp have given me enough background knowledge to start visualising an end product. I intend to use the device primarily as a mirror-mapped controller for Traktor; allowing me to control as many features in the software as possible. The majority of inputs will be buttons, but there should be a healthy selection of pots aswell for knobs and faders. Ideally, most of the buttons will have LEDs next to them to indicate their current state. I'm not fussed about having a jogwheel for scratching, and it would probably be too complex to implement anyway. I will also use the controller in FL Studio to aid in parameter control. After doing some more research on these forums, I decided on the following as a preliminary layout: PIC Based core running MIOS8 DINX4 with 32 buttons second DINX4, chained to 1st, with 16 buttons and 8 encoders DOUTX4 with 32 LEDs AINX4 with 32 pots DOGM26 lcd display Are there any obvious blunders in this design? I was unsure about the 8 encoders/16 buttons on one DINX4 arrangement, I guess this will require quite a bit of manipulation in software. I've been looking at encoders and pots on Alp's website, and to some extent they fit the bill for what I need. Does anyone know of any good suppliers in the UK, or a particularly good eBay seller? I would also like to get my hands on some encoders equipped with push switches as well, as these would be excellent for controlling loop lengths in Traktor. In terms of acquiring the pcbs, would setting up a bulk order on this forum be my best bet, or should I see if I can get them manufactured locally? I have decent electrical knowledge and respectable soldering skills, but my programming skills are still fairly meagre. I will be scouring this forum over the next few weeks to fill in all the gaps in my knowledge that I possibly can, and I'll be learning more about programming in C. Thanks in advance for any help
