sicpaul
10 -
Everything posted by sicpaul
Oh, answering that is very simple: I started DIY again 6 years ago (when my eyes have been much better than now) and after a few eurorack modules i decided to build 1 Seq4L and on big SEQ4. Knowing that my skills are not perfect i ordered 3 core PCBs and 6 years ago CORE-17 was usual. Last week i ordered a STM32F4developer board for my new core-pcb, so i will be up to date with that. But why wasting a working core-17 board? I might use it for experimenting with expansions. Cheers Paul
Thanks again. And sorry, did see your 1st reply after 15 minutes delayed hitting send button (got a phone call from my very aged mother) so it crossed :-)
I hoped to hear that and will give it a try ordering now. Thanks mate.
OK, I should have asked more precise: Will anyone with more abilities than me in reading datasheets and more abilities in identifying incompatibilities and more experiences with processor-boards help me deciding if actual offered LPCXpresso1769 with CMSIS-DAP is compatible with the old LPCXpresso1769 boards. I'm sorry to say, that neither my eyes (getting old) nor my skills in rapid searching are good enough to do it myself. https://www.embeddedartists.com/products/lpcxpresso/lpc1769_cmsis_xpr.php Thanks in advance.
I'm looking for a Processor to put in my old and working (second) MBHP-LPC17 board, but I couldn't find any LPCXpresso1769 anymore. Instead i found a few "LPCXpresso1769 with CMSIS-DAP" whatever that is. The LPC1769-part of it is looking quite similar to my processor, will that work? regards paul
Hi TK, I have a lot of GrooveBoxes (Roland MCs, Electribes, Seq4L, MidiREX) and on most devices there is the same problem in connecting with a master clock device while receiving notes from other devices. So i need mergers. But i want to merge all signals EXCEPT clock signals (#FA, #FB, #FC, #F8). And sometimes I like to split MIDI IN into a MIDI OUT(1) containing all data except clock signal and a second MIDI OUT(2) which only takes the clock signals. I could do it with a big machine, but i prefer little boxes (more useful if only taking a few devices to a session). So i struggled over your very easy to build MIDI Merger based on 16F88. I'm going to build that on stripboard anyway after my coming vaccation, but few questiones occure now: How does it handle incomming clock signals from both inputs? (I have no plan on programming PICs - so i can't follow the code by now - this might change in future :rolleyes: ) Are Clock signals only taken from IN 1 or first sending clock is the one who can send? Is it easy to add a second MIDI-Out to the merger which carries only incomming clock signals? If so i think it will be an interesting "swiss knife" for a lot of GrooveBox owners. Thanks anyway for all your efforts to DIY community! Best regards Paul
Danke, danke, danke! Uff ... ich zweifelte schon .. zumal ich erst mal drei CORE17 aufbauen will (2x SEQ4L, SEQ4) und womöglich später noch ne MIDI-Box. Nun haben alle 3 LPC1769 ihren Bootloader und sind in der Trennungsphase. Noch mal Danke für Eure Hilfe. Gruss (sic)Paul
Hi housemaster, erst mal vielen Dank für Dein Bemühen! Hab ich gelesen (siehe erste Frage). Genau hier scheiter ich. Der "Debugger" ist wahrscheinlich das Programm "LPCXpresso_v4.2.0_246.exe" (im Folgenden kurz: LPCX-Prog). Der MIOS32 Bootloader ist im Archiv "http://www.ucapps.de/mios32/mios32_bootloader_v1_007.zip" und dort im (entpackten) Ordner "MBHP_CORE_LPC1769". Dort gibt es "project.bin" und "project.hex". Wenn ich im (registriert und freigeschalteten) LPCX-Prog auf das Flash Symbol klicke, zeigt es mir an, dass kein Projekt geladen ist. Erstelle ich ein neues (leeres) Projekt, klicke dann auf Flash, heisst es "no MCU information". Versuche ich ein project zu importieren und gebe als Pfad den Ordner "MBHP_CORE_LPC1769" an, werden im "project Explorer des Programms der für den Import vergebene Name und die drei Dateien log.txt/project.hex/project.bin angezeigt, aber bei Klick auf Flash heisst es wieder "no MCU" information. Ich drehe mich im Kreis. Wie bekomme ich den Bootloader in das Programm, so dass es nicht meckert? Gruß Paul
Liebe uCApps-Gemeinde, ich komme einfach nicht weiter. Löten kann ich. SEQ4Light ist fertig. Bis auf den Prozessor im CORE17. Aber mein Englisch ist zu schlecht, um aus den zu vielen Infos und dem Wust von Möglichkeiten alleine mein LPC1769 lauffertig zu machen. Es heisst: "Once the IDE has been installed, another registration has to be done to enable the LPC-Link interface - ready! " Ja, aber wie? LPC-Link via USB am Rechner, das Programm "LPCXpresso v4.2.0_264" gestartet. Und nun? Try&Error ist ohne Treffer auf Dauer nervtötend ... Vielleicht hat hier jemand einen heissen Tipp für mich Many thanx Paul
Hallo, erst mal ein grosses Lob an Thorsten für diese Seiten und Projekte!! Ich hab ein (Verständnis-) Problem mit dem LPCXpresso für das Core17 Board. Noch habe ich das LPC1769 Board nicht auseinandergesäbelt. Die Software "LPCXpresso v4.2.0_264" ist heruntergeladen, unter Windows7-32 installiert und aktiviert. Das LPC1769 ist via USB am PC. Ich klicke wie bei "mbhp_core_lpc17.html" auf das Flash-Symbol, aber statt mir eine Auswahl an LPC Boards zu ermöglichen und danach ein .bin file aussuchen zu lassen, werde ich aufgefordert "select ONE project" aber die Liste ist leer. Wie bekomme ich das MBHP_CORE_LPC1769 project.bin oder project.hex (MIOS32 Bootloader) in das Programm? Soweit ich es richtig verstanden habe, ist dies nötig, damit der "Target" genannte Teil vom anderen Teil getrennt werden kann und hinterher im CORE17 über die Core-Platine via USB mit den restlichen Programmteilen versorgt werden kann (quasi als bios, um die USB und MIDI Anschlüsse zu initialisieren). Core17 und SEQ4Lite boards sind aufgebaut. SEQ4 folgt. Wenn SEQ4Light aufgebaut und das entsprechende Programm eingespielt ist und man ein Display anschliesst, wird dort etwas angezeigt? Sorry, für die dummen Fragen. Gruss Paul
