46 -
Everything posted by Napalmtree
My power supply failed and took the sammichFM out with it. I replaced the rectifier and VREG and am getting proper voltages across the board except some of the digital 5V spots. Mem banks 2 on right all have digi 5v, but the PIC, midi chip, 3 left mem banks, and upper board socket are onpy getting 1.76V. Nothing looks burned and diodes check out. Wondering what could be shorting that line and not affecting the mem banks. Thinking it's either IC caps or a transistor. Any ideas welcome. Gotta bring this back to life. The failed supply spiked voltage up to 15V+
yea i've been checking. oh sweet. I do have access to a mill that uses eagle thankfully. Just looking to revamp my old boards as it's been like 5 years of wear n tear and upgrading housing plus kinda want to make a second one for a friend. There should be a midibox for everyone kickstarter project where we produce more parts than anyone would ever need to make sammiches and midiboxs. Leave no nerd behind.
Looks like the smash TV shop has ramped down inventory and sammich kits are long gone. Anyone know where to get new Midibox SID V2 kits or the successors even or has no one stepped up to sourcing these anymore?
https://soundcloud.com/televicious/b2-1 Can't wait to see what I can do with it once I finish filters for it, but It makes great sounds regardless. This is a recording of it playing in one shot. I sequenced it in renoise and just did a straight recording.
MIDIBOX SID always formatting bankstix, even when none connected
Napalmtree replied to djvinz's topic in MIDIbox SID
So I had this problem and fixed it with the 1k resistor going from D3 to a 5V+. My midibox was shorting out so I was going through re doing some solder joints including the 1k resistor and now it's back to it's reformatting old self. The Diode appears to be functioning according to my multimeter. It's the Core_R4D board btw. I should also note, it's only formatting Bank G and the Ensembles. usually the ensembles. I got new diodes and resistors for it. If that does the trick I'll be at ease otherwise I'm clueless. -
Awesome. Thanks for the reply! At the very least I can use a cheap homemade filter. Break out cabling it is.
Could you use a shruthi filter?
Interesting, the midibox FM did a fine job at making it 6 voices then. Playing with adlib tracker 2 I noticed this MIDI issue with the MPU-401 cable. If i played the notes with a normal computer keyboard It had no problem keeping up, in 18 channel 2 op mode I'm pretty sure i heard every channel. Midi mode was channel to channel. I wonder what they did to make the computer keyboard perfect at polyphony in preview modes.
YES! The only thing I can add is, please make the stereo mixing midi controlled. That 18 channel + optional mixed mode is brilliant. I would love to see that with the AOUT modification. This will make Adlib tracker 2 obsolete to me.
I'd be interested in that CAD file if you still have it. Have access to a laser cutter and lots of C64 cases to work with. :D
woah! :o Awesome project!
Basically, MIOS needs to be rewritten from scratch and the whole user interface will need to be reassigned/redesigned. The source is included with MIOS. Let me know how it turns out! I just went on to working with a SB16 Adlib Tracker 2 and ancient MPU-401, though the Midibox version is still fun to toy with and more portable too.
I've been scouring the internet. I don't think anyone's touched the sega saturn's YMF292 SCSP. The only ways I've found for people to do anything with this chip are mario paint style games or if you buy Sophie (saturn dev kit) from ebay for 600 bucks. Surprised no one's pulled the chip or written a music controller/sequencer program. There was a Japanese game that was basically piano hero that came with a midi interface, but no music creation or sound controls.
well 15 plus drums makes it perfect for midi's 16 channels anyhow right? Have any links to your project?
I just recently discovered trying to control the Audio routing via CC parameters does not function. Is this common for everyone or may it just be Renoise which I'm using to control it with? I've tried the voice CC with no success. I understand the ensemble cc's are only functional with Sysex.
I got my sammichFM second hand so I didn't get to build it, but I looked around on the board and didn't see anything obvious to setup an AOUT module to add a filter. I'm sure it could be customized, but I thought I'd seek pro tips on if AOUT's were planned ahead for with the sammichFM.
Thanks I just got that. I saw in the wishlist a multimode instrument list to switch instruments on the fly. That makes me very excited because trying to sequence anything in MSSIAH with a joystick or digital converted mouse is like trying to bite your own ear, for hours on end.
So playing with arpeggiations with gate length maxed out it plays back just fine. When I shorten it, it starts to miss a step or be off a step every so often. I also noticed when playing back some SID files like platoon it will do the same thing on some of the arpeggiated parts. It must be my build or something. Has anyone else experienced this?
Ahhhh HAH! thank you sir! i thought there was a way. Why haven't I been using the higher res automation all along?! back to the sequencer.
Has anyone tried to make custom MIOS edits to add a few MIDI CC parameters to multimode? It's my favourite mode on the beast and would love to run it with some PW and filter effects automated. Guess I could try playing with the script, but I'm a n00b.
http://noplanet.bandcamp.com/album/planet-nos-greatest-hits Released work.
here's three, Filtered poly is just a slight tweak on the original BassSnatch is two sequences split between left and right SID channels with 5 presequenced bits Big Black is a nice heavy sounding bass and snare with the drum line from big blacks bad houses meant to be played around 50 bpm enjoy! couple custom.zip
Panel link is dead. The stock patch banks you guys made won't load in the mios studio or patch turkey or any other patch librarian i've found, says the banks are corrupt as they are not the proper length. I managed to use the bank that comes with patch turkey for the first one, but the second bank is not included. ahhh found a working one http://ctrlr.org/panels?get&idx=63
I was curious after looking up the data sheet on opl3 and think 18-channels would be amazing for using with dosbox or adlib tracker II. Since MIDI is only 16 channels though I wonder if you could do 2 4ops and 12 2ops for 14 channels or 1 4op 14 2op and drums for all 16. After playing with yamaha 2op keyboards from the 80's I realized even 2ops can do a lot and using the General Midi compatibility in dosbox gives game soundtracks a crazy new spin as i've played around with on the sammichFM. Will have to try the LPC17 build someday.
http://www.ugcs.caltech.edu/~john/computer/opledit/tech/opl3.txt ah, I meant 18 channel mode. that is 18 2-op instruments. I suppose that is a lot less useful than 36 ops in a single instrument.
